Nothing happens when waterfall clicked
I bought my RSP1a today. All seems to be working, except I can't get the radio to change frequency when I try to click a signal on the waterfall. Is there a setting I need to activate? I can't seem to find it in the manual.
Thanks, Dean.
Thanks, Dean.
Re: Nothing happens when waterfall clicked
I am using it as a panadaptor off the IF of my FT991. I have discovered that when I disable the IF output frequency, I can navigate around the screen with the PC mouse, but lose the signals as the IF is not locked. Is there any way around this?
Dean.
Dean.
SDRuno does not presently support clicking on the waterfall and changing frequency on the radio. If you want to do this you will have to use SDR-Console or HDSDR.
I had the same Problem. So i found out the following workaround:
If you can not change the Frequency by clicking on the Waterfall just rightclick on
the Spectrum outside the Filter area. Then you can chose a Frequency by clicking on
the Waterfall. This solved my Problem on my Windows-PC.
73 de Hans-Juergen
73 de Hans-Juergen
