Nothing happens when waterfall clicked
Posted: Fri Sep 28, 2018 10:12 pm
by DeanG4WQI
I bought my RSP1a today. All seems to be working, except I can't get the radio to change frequency when I try to click a signal on the waterfall. Is there a setting I need to activate? I can't seem to find it in the manual.
Thanks, Dean.
Re: Nothing happens when waterfall clicked
Posted: Sat Sep 29, 2018 8:33 am
by DeanG4WQI
I am using it as a panadaptor off the IF of my FT991. I have discovered that when I disable the IF output frequency, I can navigate around the screen with the PC mouse, but lose the signals as the IF is not locked. Is there any way around this?
Dean.
Posted: Sat Sep 29, 2018 5:35 pm
by Roger
SDRuno does not presently support clicking on the waterfall and changing frequency on the radio. If you want to do this you will have to use SDR-Console or HDSDR.
Posted: Fri Nov 23, 2018 11:10 pm
by HansDG8OBF
I had the same Problem. So i found out the following workaround:
If you can not change the Frequency by clicking on the Waterfall just rightclick on
the Spectrum outside the Filter area. Then you can chose a Frequency by clicking on
the Waterfall. This solved my Problem on my Windows-PC.
73 de Hans-Juergen
