RSPduo and Dump1090 - Filters?
I2SVA
Postby I2SVA » Sun Oct 14, 2018 9:00 am
Hi readers and Support,
how can I set the mw/fm filter and/or the DAB filter on in Dump1090?
I tried the argument rspduoNotchEn (not sure it is the right one) but it always returns "Unknown or not enough arguments for option "rspduoNotchEn"
Thanks!
Alessandro i2sva
Re: RSPduo and Dump1090 - Filters?
Postby sdrplay » Sun Oct 14, 2018 9:33 am
There is currently a bug with the notch filter implementation.
I'm adding this now...
"--disable-broadcast-notch   Disable Broadcast notch filter (RSP1A/RSP2/RSPduo)"
"--disable-dab-notch         Disable DAB notch filter (RSP1A/RSPduo)"
and the default state is enabled.
I'll post a link when the new download is ready.
I2SVA
Postby I2SVA » Mon Oct 15, 2018 6:33 pm
Thanks, this is good and I look for the link.
Please note that when I start SDRuno with Filters enabled it works like the filters are disabled, i.e. I have to disable the filters in SDRuno and then re-enable in order to have the filters working properly.
Is this a known bug?
Alessandro i2sva
Postby sdrplay » Thu Oct 18, 2018 8:54 am
https://www.sdrplay.com/software/SDRpla ... r_1.42.exe
By default the notches are now enabled and the command line options I mentioned above will disable them.
Please let me know how you get on and I'll then create the non-Windows versions for download.
Postby sdrplay » Thu Oct 18, 2018 8:56 am
With regards to SDRuno, v1.3 is in development right now, so I'll check that behaviour and if it's broken, I'll fix it.
I2SVA
Postby I2SVA » Mon Oct 29, 2018 4:06 pm
Hi Andy,
sorry it take so long, finally I had the time to test the new software and "wow!" finally it started very well (just double-clicking start8i) and immediately started listing tenths of aircrafters.
With a second click I started the Virtual radar server and the browser map was immediately populated.
That's a very good job, congrats!
Alessandro, I2SVA
Postby sdrplay » Mon Oct 29, 2018 4:32 pm
Thanks for the feedback - I'll get it released.
