Connecting to Soapy Remote
I have spent the morning scanning through various documents like
https://github.com/pothosware/SoapyRemote/wiki
But am yet to find the default port number to connect to / enter in to CubicSDR to connect to my Soapy Remote server
If I run CubicSDR it DOES appear on the devices tab under ‘Local’ and it works correctly
What I wanted to do was to connect to it from outside my home network... So run CubicSDR or SDR# on a computer outside my home network, then connect to it via accessing my home via DynamicDNS, and port forwarding
That is possible right?
I just need the port number.
Also read I may need to Force TCP as it defaults to UDP
Do I have to force bind to a specific port or does it have a default ?
I have Soapy Remote running using this tutorial
Forcing it to start on boot using
Systemctl enable
Systemctl enable
Re: Connecting to Soapy Remote
OK, since no one knew I opened a Issue on github
its seems the standard default for port for Soapy Remote is 55312 if you want to listen to SoapyRemote remotely
