Command line interface for RSP1a
keyboardbandit
Postby keyboardbandit » Thu Jan 17, 2019 1:21 am
Hello all, first time poster here and I'm hoping you can point me in the right direction. I have a SDRPlay RSP1a and a Raspberry Pi3, I need to send raw I/Q data from the SDR to a UDP port. I have been doing this with GQRX to send the data to udp, but now I need to be able to set up and run the SDR with a bash script or some other automated way and pipe the raw I/Q data to the same port.
I've spent the past few hours trying to get SoapySDR to work on the pi, right now running "SoapySDRUtil --find" returns no devices found. I think that rx_sdr should be the tool I need, but I'm not sure because I am new to all of this.
Any advice you all can offer would be greatly appreciated.
Last edited by keyboardbandit on Thu Jan 01, 1970 12:00 am, edited 0 times in total.
fventuri
Re: Command line interface for RSP1a
Postby fventuri » Thu Jan 17, 2019 3:29 am
You may want to make sure you have installed the SDRplay API driver for Raspberry Pi (https://www.sdrplay.com/downloads/) and the SoapySDRPlay module (https://github.com/pothosware/SoapySDRPlay) on your Raspberry Pi 3.
Also does the command:
lsusb -d 1df7:
return anything back?
If not, it might be a sign of a problem with the USB connection itself.
Franco
keyboardbandit
Postby keyboardbandit » Thu Jan 17, 2019 7:38 pm
fventuri wrote:You may want to make sure you have installed the SDRplay API driver for Raspberry Pi (https://www.sdrplay.com/downloads/) and the SoapySDRPlay module (https://github.com/pothosware/SoapySDRPlay) on your Raspberry Pi 3.
lsusb -d 1df7:
Franco
Hi there, thanks for your reply. Running "lsusb -d 1df7:" returns "Bus 001 Device 004: ID 1df7:3000"
I have also downloaded and installed the SDRplay API driver and the SoapySDRPlay module as well as the rx_tools. I'm really scratching my head here because if I open GQRX I can select and use the device SDRplay RSP1A and it seems to work just fine. I can type rx_sdr and get the usage info about rx_tools, but when I type "SoapySDRUtil --find" I get a message saying No devices found.
I'm thinking today I will reimage the sd card and start over from scratch without installing gqrx first?
fventuri
Postby fventuri » Thu Jan 17, 2019 10:27 pm
According to the documentation here https://github.com/pothosware/SoapySDRPlay/wiki#probing-soapy-sdr-play, the command you should be using to make sure SoapySDR can see your RSP device is:
SoapySDRUtil --probe="driver=sdrplay"
I just tried it on my computer and the result should look something like this:
##     Soapy SDR -- the SDR abstraction library     ##
Probe device driver=sdrplay
-- Device identification
  driver=SDRplay
  hardware=********
  mir_sdr_api_version=2.130000
  mir_sdr_hw_version=2
-- Peripheral summary
  Channels: 1 Rx, 0 Tx
  Timestamps: NO
  Other Settings:
       [key=rfgain_sel, default=4, type=string, options=(0, 1, 2, 3, 4, 5, 6, 7, 8)]
     * ExtRef Enable - External Reference Control
       [key=extref_ctrl, default=true, type=bool]
-- RX Channel 0
  Full-duplex: YES
  Supports AGC: YES
  Stream formats: CS16, CF32
  Antennas: Antenna A, Antenna B, Hi-Z
  Corrections: DC removal
  Full gain range: [0, 47] dB
    IFGR gain range: [20, 59] dB
    RFGR gain range: [0, 8] dB
    CORR freq range:  MHz
  Sample rates: 0.25, 0.5, 1, 2, 2.048, 6, 7, 8, 9, 10 MSps
  Filter bandwidths: 0.2, 0.3, 0.6, 1.536, 5, 6, 7, 8 MHz
Franco
