380-430 MHz. ?
Posted: Sat Dec 26, 2015 4:08 am
According to a review in the Spectrum Monitor, reprinted at http://swling.com/blog/2015/07/a-review ... -receiver/ the writer says:
"...the SDRplay RSP also has an exceptionally wide frequency range covering from 100 kHz to 2 GHz, with only a narrow gap between 380 MHz and 430 MHz. ..."
When I tried my new SDRPlay using HDSDR it seems to work fine thru this range.
Was this a limit on early versions, a software issue or just an error on the part of the writer?
