Scanner in SDRuno Always switches to ANT-B
Looked through the manual and the forum and did not see this discussed. I have the RSP2pro and when I start up the scanner the SDRuno software switches to ANT-B. Is this normal operation? How can I have scanner function on ANT-A?
Thanks, John.
Thanks, John.
Re: Scanner in SDRuno Always switches to ANT-B
Maybe the scan mode is at memory not at range. If this is the case, the saved frequencies are in ANT-B at the memory bank you are scanning.
