Re: SDRPlay Issues with Xubuntu 15.10 while building gnuradio-osmosdr
Posted: Sun Jan 31, 2016 7:11 pm
So my last post is still in moderation but I followed instructions in post after initial Soapy build failure and stepping though these installs worked, went back to build CubicSDR with Success!
Current Build of all the things:
Note to self, 'ldconfig' is your friend after liquid and Soapy builds succeed, I omitted this step in my first attempt, and usually know better.
So, my install order:
# lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 15.10
Release: 15.10
Codename: wily
# uname -a
Linux CORQBUNTU 4.2.0-25-generic #30-Ubuntu SMP Mon Jan 18 12:31:50 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
# SoapySDRUtil --info
API Version: v0.4.1-g0768722a
ABI Version: v0.4-2
Install root: /usr/local
Module found: /usr/local/lib/SoapySDR/modules/libsdrPlaySupport.so
Loading modules... done
Available factories...null, sdrplay,
- Install API from SDRplay.com as normal
- install newest versions of SoapySDR from their github:
https://github.com/pothosware/SoapySDR/wiki
https://github.com/pothosware/SoapySDRPlay/wiki - install liquiddsp and other dependencies for CubicSDR, instructions here: https://github.com/cjcliffe/CubicSDR/wiki/Build-Linux (I did not require wxWidgets step)
- PROFIT!
