Mode A & Mode C (Mode S, ADSB)
9a4db
Postby 9a4db » Fri Mar 04, 2016 4:51 pm
Any one know working solution for SDRPlay use on Mode A and Mode C 1090 MHz reception and decoding?
Any platform Win, RPI or Ubuntu... but Win 10 preferable.
At the moment using SDRPlay with SDR# and ADSBPlugin with ModeSMixer2
Mode S and ADSB working fine,
after learning to live with glitch and bugs
Tnx
NN4F
Re: Mode A & Mode C (Mode S, ADSB)
Postby NN4F » Fri Mar 18, 2016 6:41 pm
Sdrplay have just released a windows version of dump1090 for testing, works great so far with VRS... Very pleased
Paul - NN4F
0815
Postby 0815 » Fri Mar 18, 2016 8:46 pm
hi,
can you tell me where to download?
thx
Fractal1
Postby Fractal1 » Fri Mar 18, 2016 10:41 pm
Fantastic! We've all been waiting for this, but where can i find it?
Postby sdrplay » Sat Mar 19, 2016 1:34 am
Windows: http://www.sdrplay.com/software/SDRplay ... ws_0.1.zip
extract files and run dump1090_sdrplay with command line options in a command prompt. The built in HTTP server doesn't work yet so suggested use is to created a start.bat file containing...
.\dump1090_sdrplay.exe --interactive --net --net-ro-port 30002 --net-beast --mlat
then install virtual radar and it works just fine from there.
For non-Windows OS there are two versions of dump1090 on our github repository...
https://github.com/SDRplay/dump1090 - this is the same version as the Windows one
https://github.com/SDRplay/dump1090_sdrplus - this version has support for RTL, HackRF and Airspy as well as the RSP now.
Both require building, for the dump1090_sdrplus version, check the build_libs.txt file with a guide to how to build all the dependencies.
NOTE: This is the first release and some functionality (change gain, frequency, AGC) has been removed as we are still optimising and improving the system. Future updates will have those features back in.
We are also putting an installer and documentation together for the Windows version to make it more user friendly. Check back for updates.
w2dsx
Postby w2dsx » Sat Mar 19, 2016 3:58 am
This is simply outstanding!! Many thanks to all who accomplished this!
Fractal1
Postby Fractal1 » Sat Mar 19, 2016 12:06 pm
AWESOME!!Thank you SDRPLAY, i want the team of coders and testers to know how much us end users appreciate what you are doing! Keep it up!! :D :D :D :D :D
Postby 0815 » Sat Mar 19, 2016 5:29 pm
Perfect!!! Thanks
Fractal1
Postby Fractal1 » Sun Mar 20, 2016 4:33 am
I have it running with Plane Plotter, looking good so far.
Rebel
Postby Rebel » Sun Mar 20, 2016 7:32 pm
Thanks a lot to the team, works fine on Linux here and with much better performance than with RTL Stick....well done...
Fred, DL6BAW
