Page 5 of 6
Re: Using SDR# to drive the SDRplay RSP
Posted: Tue Mar 24, 2015 7:55 am
by CaptainNemo
Hi SDRplay team!
Any news about SDRplay SDR# plugin? Any plan to release a new version?
Bye
Posted: Wed Mar 25, 2015 11:27 am
by admin
Hi Captain Nemo,
We have a new version which we will be releasing tomorrow (26th March)
SDRplay
Posted: Thu Mar 26, 2015 7:25 am
by Jabi
Ok. I am also waiting the new driver compatible with the last version of SharpSdr.
Have news about aucun software for Android?
73,s de Jabi, ea2aru.
Posted: Thu Mar 26, 2015 10:29 am
by jon
We've just released the new SDR# plugin - see There's a new release of the SDR# Plugi ... Rsharp.htm
It has the following:
- Updated GUI with new Gain control interface
•Fixed LNA Threshold control bounds
•Added slider to LNA threshold
•Added Tool Tips
•Frequency Trim in PPM added
let us know how you get on with it.
Posted: Thu Mar 26, 2015 8:02 pm
by CaptainNemo
Hi.
I downloaded SDRplay SDR# Plugin v 1.5 few moments ago and now it's up-and-running.
Thank you.
73
Posted: Thu Mar 26, 2015 8:06 pm
by jon
Glad it's working captain nemo :-)
Posted: Thu Mar 26, 2015 10:01 pm
by JMG
Works great. Some real improvements. Thanks.
Posted: Thu Mar 26, 2015 10:21 pm
by JMG
Using SDRplay SDR# plugin to drive SDRplay under SDRSharper.
SDRSharper and SDRplay RSP: a very harmonic combination!
In order to install SDRplay-SDRSharp-Plugin-v1.5.exe to SDRSharper-02g,
SDRSharper.exe
SDRSharper.exe.config
have to be renamed to
SDRSharp.exe
SDRSarp.exe.config
Posted: Fri Mar 27, 2015 2:35 pm
by CaptainNemo
Hi JMG
I got 02.f
I suppose 02.g is newer ...
Where can I get it?
TNX
73
Posted: Fri Mar 27, 2015 3:09 pm
by DaveB
Version 1.5 of the plug-in has solved an issue with unreliable tuning I was about to report. The auto IQ imbalance is still not working so still an issue with annoying IF images on strong signals when tuning around. Hopefully the SDR team will be able determine whether a change in the plug-in will fix it or if it's a problem embedded in the latest builds of SDR#.
However - if you stay tuned to the centre frequency it isn't an issue so for my intended use of Jeff Knapp's frequency scanner - as I've noticed that the latest version stays locked to the centre frequency when scanning. Linking up Jeff's scanner plug-in with Andy Pritchard's RDSDataLogger, set to current frequency rather than scan, should give a nice unattended monitor for SpE openings - although the RDS sensitivity isn't as good as RDSSpy in conjuction with HDSDR.
Rgds
David
