USB Isolator
lew247
USB Isolator
Postby lew247 » Fri Apr 24, 2015 7:13 am
Will SDRPLAY work with usb isolators?
The common ones seem to have Full speed data rate 12 Mbps
Will this be enough for the SDRPLAY?
TyTanYGraig
Re: USB Isolator
Postby TyTanYGraig » Sat Apr 25, 2015 11:15 am
No, your hub will have to support High Speed USB 2.0. To support 8 MHz sampling for both I and Q with 12 bits each, the USB rate will be close to 200 MBPS. The lowest sample rate is around 1.5 MHz, and this still requires around a USB throughput of around 36 MBPS
TyTanyGraig
berghauz
Re: USB Isolator
Postby berghauz » Sun Nov 01, 2015 9:07 am
Hi!
What about sample rate for 200khz bandwidth?
According to http://swling.com/blog/2014/08/london-shortwave-refines-his-tablet-based-portable-sdr/ ISO2USB work well.
UA3152SWL/KO85vq
