EXTIO plugin 3.9.1 loss of Frequency Trim?
K4KDR
Postby K4KDR » Wed Jul 13, 2016 12:54 am
Greetings!
After installing the 1.94 API and 3.9.1 ExtIO, the "Frequency Trim (ppm)" on the ExtIO screen no longer seems to have any effect.
Am I overlooking something that I should be doing differently?
-Scott, K4KDR
Montpelier, VA USA
Re: EXTIO plugin 3.9.1 loss of Frequency Trim?
Postby sdrplay » Wed Jul 13, 2016 6:03 am
There was a bug in the ppm trim using 1.94 of the API, please update to 1.95
Also, currently in 3.9.1 of the EXTIO plugin, it's necessary to stop/start the stream to see the ppm change.
Flyingscot
Postby Flyingscot » Tue Nov 15, 2016 1:20 pm
Not realising that Freq trim no longer works in realtime I spent ages thinking I was doing something wrong today :x
Is the ppm trim going to be fixed so that it is possible to change it in realtime in HDSDR EXTIO plugin? It isn't very easy to make fine adjustments if you have to stop and start each time you make an adjustment.
It used to work didn't it? Can I revert to a previous version that had the functionality?
Richardovellee
EXTIO plugin 3 9 1 loss of Frequency Trim
Postby Richardovellee » Mon Dec 19, 2016 9:44 pm
hey guys, im doing a head unit for a mate on monday just wanted to know is the trim easy to click off to get to old head unit out? where should i start?
Last edited by Richardovellee on Thu Jan 01, 1970 12:00 am, edited 0 times in total.
