Disaster with API 1.94 (*1.95) and Sharp 1361
DaveB
Postby DaveB » Thu Jul 14, 2016 2:01 pm
I installed API 1.95 and installed the latest ExtIO to HDSDR folder. That is all I dsid - HDSDR works - but I think the decimation is flaky.
Then I went back to my tried and tested SDR# build 1361 - and it just sat there not running SDRPlay!!! Just a blank waterfall.
So I uninstalled Mirics 1.95 - rebooted and then re-installed API 1.8.1 - and SDRSharp build 1361 still won't work!!
So until I can find out what has gone wrong - with the help of SDRPlay support - DON'T install the new API if you are running Sharp 1361. It appears to break it.
Hope the moderators will fast track this post - cos until we get decent recording facilities and a 192 kHz audio output to RDSSpy - SDRUno doesn't match my needs and the needs of other FM-DXers.
David
Re: Disaster with API 1.94 (*1.95) and Sharp 1361
Postby sdrplay » Thu Jul 14, 2016 3:46 pm
Hi Dave,
Strange, 1361 working fine here. I would suggest cleaning out the registry by removing...
[HKEY_CURRENT_USER\Software\SDRplay\Settings]
Contact us at support@sdrplay.com if you are still having problems and we'll get to the bottom of it.
