SDRPlay +FT2000 and HRD
on6dp
Postby on6dp » Thu Aug 25, 2016 1:55 pm
I have recently bought a SDR PLay and I'm trying to install and run SDRUNO with my FT-2000 and my PC AMD Phantom X 64 bits with 16 GB RAM
I have also a Digikeyr from Microham
But I have few difficulties to can run all ingood conditions, particularly with sound and COM ports
Anybody can help me ?
Paul, ON6DP :oops:
73 de Paul, ON6DP / OP0P
on6dp
Re: SDRPlay +FT2000 and HRD
Postby on6dp » Fri Aug 26, 2016 9:59 am
In complement of my previous request, I have remarks that the 1.95 don't install correctly on my AMD Processor PC and on my 2 others PC under INTEL Processor, I can install the 1.95 without problems. Anybody has encountere the same problem and same remarks ??
on6dp,Paul
Misterj
Postby Misterj » Fri Aug 26, 2016 6:59 pm
on6dp, I did see your install problem post but did not understand exactly what problem(s) you are having. Please post more information including what system you are running. If W10, please post the version (open administrator command prompt and enter winver). Please post any error message(s) you are getting (screenshots are good.) I have an AMD machine running W10 version 1511 and have no problems but I may have not tried what you are doing. The CPU vendor should make no difference but the system version may well. Enjoy, John.
on6dp
Postby on6dp » Fri Aug 26, 2016 9:17 pm
Hi Misterj,
So i resume my problem
Here I have
FT-2000D Yaesu with Microham Digikeyer connected to FT-2000
I have the SDR Play connected via USB to my PC
I have launch the uRouter of Microham
So 2 virtual ports are created. In my case COM5 and COM7 that I'm using for HRD to switch in PTT
so with my Microham U have an USB Codec for input and output
I have tried SDRUno SDR-COnsole and I have the same sound problem
The CAT seems to run but my problem and questions are around sound
1.) must I have an ASIO file ExtIO.dll or no extIO.dll when I m using SDR-COnsole 3
2.) how to configure the sound
3.) Must I put an IF frequ in the program linke 10,550 Mhz or 69,450 Mhz for my FT-2000
4.) Is it possible to have HRD and SDRPLay WITHOUT Microham System or just without uRouter from Microham?
Where exactly must I connect the SDRPLay into the TRX? I'm looking for dou to see if the connection I have made is well done.
Is it better infos to can help me ?
73 de Paul, ON6DP (on6dp@on6dp.be)
on6dp
Postby on6dp » Fri Aug 26, 2016 9:22 pm
Oh Misterj I have forgotten
I have WINDOWS 8.1 64 Bits with 16GB RAM with AMD Phenom II X6 1100T Processor 3,30 GHZ (6 cores)
Paul, ON6DP
Misterj
Postby Misterj » Sat Aug 27, 2016 3:03 pm
on6dp, I thought you might be having driver problems with the latest version of W10. Sorry, I cannot help with your problems. Have you tried the Contact page? Enjoy, John.
on6dp
Postby on6dp » Tue Sep 06, 2016 1:41 pm
I have Windows 8.1
Yesterday I have tried with an mobile antenna and then all is ok and the waterfall run well
But when I put the FT-2000D no
So I mean I put into de SDR Play the IF Out of transceiver and maybe I must put in SDRUno the IF Frequ 69,450 Mhz
73 de Paul, ON6DP
tatamare
Postby tatamare » Tue Sep 06, 2016 9:57 pm
For the Yaesu FT2k and any other radio with RX IN/OUT connectors. No IF tapping, no soldering required.https://m.youtube.com/watch?v=StcIIDOySqg.
Only spliter, and for sync use omnirig,HDSDR and sdr console suport it.
Gl and 73 by yo7fb.
o
