Antenna switch for hf and inmarsat?
Fractal1
Postby Fractal1 » Tue Aug 30, 2016 8:43 am
Can anyone recommend a switch to buy or a design that will allow me to switch between hf and inmarsat frequencies? i have tried the ones designed for cable tv/satellite with the f connectors, but the loss of satellite signal is too great. constantly changing antennas could end up stressing the SDRPlays only antenna input.
Many Thanks.
Scannerz
Re: Antenna switch for hf and inmarsat?
Postby Scannerz » Fri Dec 16, 2016 9:51 pm
This is the one I have,(actually I have two grouped together = 5 inputs) Goes up to 1500mhz and works well...
http://www.moonraker.eu/amateur-radio/c ... oax-switch
or to 3000mhz...
http://www.moonraker.eu/watson-cx-sw2n- ... oax-switch
Just ordered a couple of "SMA female to SMA male plugs" from AliExpress ....or ebay.
Figured if they wear out, I`ll only have to replace the sma plug adapter and not the soldered female sma on the SDRplay.
cheers Tony.
Fractal1
Postby Fractal1 » Sun Dec 18, 2016 8:37 am
Thanks Tony, i'll check them out.
Richardovellee
Postby Richardovellee » Mon Dec 26, 2016 9:21 am
I have a Tank whip, really good antenna and great value for money, SWR is fantaastic on it
Last edited by Richardovellee on Thu Jan 01, 1970 12:00 am, edited 0 times in total.
