Is it over kill toshield your RF ground if its far away?
Posted: Sun Oct 16, 2016 5:19 pm
by bubblegumpi
I like listen to short wave on my SDR with a wire antenna. heres the thing my radio is on the second flood and to get a wire to the ground rod it must pass across a room (20 feet) then put the windown then down about 20 more feet. I do have a whole bunch of extra coax that I found some where. Is it ok to just run a wire this long distance to the ground rod? Thats like a 40+ foot length and I'm afraid it will become a noisy antenna. I could hook the center of a coax cable to the ground, run it into the house across the room and then ground my radio with it. Over kill or a good use of this huge pile of coax I have?
Re: Is it over kill toshield your RF ground if its far away?
Posted: Mon Oct 17, 2016 9:46 am
by F1BJB
Hi
Where would you connect the shield of your shielded ground ?
To avoid ground loops between the AC plug/USB ground and the RF ground on HF receive aerials.
I use small toroid transformers made with toroid core salvaged from energy saving lamps .
They are located at the base of vertical antennas or in the middle of dipoles.
As a bonus some kind of impedance matching can be achieved by adjusting the turns ratio.
