High Z with G5RV
m0pai
High Z with G5RV
Postby m0pai » Tue Jan 03, 2017 3:42 pm
I'm looking at using the High Z port of the RSP2 with the G5RV and wasn't sure if i needed to add the 1:9 Balun inline, the feeder lengh is quite long 40ft+.
Any ideas?
g7jur
Re: High Z with G5RV
Postby g7jur » Wed Jan 04, 2017 4:57 pm
Just connect it to the hi-z port, it will work fine.
Inner of the coax to P connect N und ground together and the coax outher
Philip G7JUR
m0pai
Postby m0pai » Wed Jan 04, 2017 9:48 pm
Thanks Philip,
Been running it on the High Z since yesterday and working well.
HNY 17
Regards
Adrian
joeruffer
Postby joeruffer » Tue Feb 28, 2017 9:55 pm
What connection at the Hi-Z port is made using 450 ohm ladder line?
Thx Joe KA4AMX
Postby g1hbe » Tue Feb 28, 2017 10:12 pm
Ladder line is balanced, so connect across P and N. Ignore the G terminal.
joeruffer
Postby joeruffer » Thu Mar 02, 2017 1:48 am
Thx so much. I wanted to be sure nothing was needed to match the 450 ohm ladder line to the 1k ohm impedance listed for the High Z port.
THX AGAIN
Joe KN4AMX
Postby g1hbe » Thu Mar 02, 2017 1:05 pm
No problem. 450 ohm into 1k is regarded as a good match, as it's only a 2:1 ratio. On receive it makes little difference anyway. Happy twiddling!
ekendraed
Postby ekendraed » Sun May 07, 2017 3:01 pm
