RF Preamp
starlite
RF Preamp
Postby starlite » Fri Jan 19, 2018 10:58 pm
Newbie question.. Would an RF pre amp overload the input of my SDRplay?, I didn't try it yet but I don't want to damage my unit...
Re: RF Preamp
Postby g1hbe » Sat Jan 20, 2018 11:20 am
You shouldn't need a pre-amp on HF at all, as reception is limited by external noise. On VHF and above, you may need one if you are looking for very weak sigs like satellites etc, but the amplifier should preferably tuned to the frequency of interest (not wideband) or you can get overload and intermod effects. The RSP's are already very sensitive, so unless your feeder is very long and lossy you don't need an amp for most listening.
starlite
Re: RF Preamp
Postby starlite » Sun Jan 21, 2018 12:58 am
Ok, thanks for the info, on further looking the amp says it has a 30db gain from 01 to 2000mhz and it is powered by 12vdc so I will leave well enough alone, thanks much.
