Sangean Portable Antenna for RSP1A?
Posted: Tue Mar 27, 2018 9:33 pm
I would like to know if a portable shortwave antenna such as the Sangean ANT-60 could be used with the RSP1A for travel use. The Sangean antenna is a 7 meter/23 foot long wire antenna that terminates with a 3.5mm/1/8 inch mono plug intended to plug into Sangean radios with a corresponding antenna jack. The antenna also comes with a clip to attach to radios with a whip antenna (or bare wire into the SMA?) and conveniently rolls up when not in use.
Sorry for the lengthy description. In an earlier post I attached a link to the website for the antenna and was advised the post was rejected because "the message contains links to illegal or pirated software". Thank you
