First setup VHF 118-160 MHz
Posted: Thu Apr 05, 2018 6:36 am
by NeilP
Ok,
Not even bought the SDR box yet, but my listening requirements are pretty limited.
Just looking for monitoring of a few Air band frequencies, 119-136 MHz from local airport, 9 miles away and the local marine traffic in the 156-160. Harbour is maybe 5 miles away and I live on the coast ( Jersey, SE Corner) 12 miles or so from France.
So I have my old 2m ham collinear antenna on the floor in the attic. Been there for more than 20 years since I last operated the 2m station (Yaesu FT290)
Just plug that in to the RSP and good to go right ?
The antenna designed for 144Mhz, so should be good to go as it is right ?
Going to need adapter from the big 15mm diameter co-ax down to something for those tiny connectors on the RSP..... what are they called again ? SMC ?
Any thoughts ?
Will this be acceptable?
Many thanks
Re: First setup VHF 118-160 MHz
Posted: Thu Apr 05, 2018 12:17 pm
by NK7Z
I would certainly give that a try to start with... If you are 9 miles from where you want to receive, you should have no issues at all, assuming the feedline and antenna are still functioning. Polarization might be an issue.
Posted: Thu Apr 05, 2018 12:57 pm
by g1hbe
Neil
The RSP's use SMA antenna connectors. If your antenna cable is big & heavy, I'd recommend an adaptor lead rather than a rigid block adaptor. This will take the strain off the system. There's a company called Sinequanon that do ready-made leads and their prices are reasonable. I don't know whether they do one that would suit you.
http://www.sinequanon.co.uk/
Be prepared to root about in the various catagories as they have stuff all over the place.
Posted: Thu Apr 05, 2018 3:39 pm
by NeilP
Thanks for the link
Polarization won't be an issue once I get it out of the attic and make it vertical again. ;)
OK, so one issue sorted. Now just need to work out what to do/buy to get a system working
