50 ohm antenna connector on the SDRplay
RFRANK56
Postby RFRANK56 » Fri Nov 06, 2015 9:04 pm
IS THAT CORRECT? I cannot find the specs anywhere
RFRANK56
Re: 50 ohm antenna connector on the SDRplay
Postby RFRANK56 » Fri Nov 06, 2015 9:32 pm
I am hoping it is 75, that would work nicely
Rebel
Postby Rebel » Sat Nov 07, 2015 10:09 am
There will be no noticeable difference....
Postby g1hbe » Sun Nov 08, 2015 10:18 am
It really doesn't matter either way. I'm not sure what the nominal input impedance of the SDR play is anyway, but it sure won't be constant over the bands. And the effect of the connector's impedance will be so tiny you can ignore it.
