Antenna conector
cmgam
Antenna conector
Postby cmgam » Thu Oct 18, 2018 8:28 pm
Hi
What type of connector to connect the antenna to SDRplay.
Thanks in advance
Regards
cmgam
AussieSusan
Re: Antenna conector
Postby AussieSusan » Fri Oct 19, 2018 1:54 am
Check the data sheet for the particular hardware you are interested in. For example the RSP2 uses SMA female connectors.
Susan
Postby g1hbe » Fri Oct 19, 2018 7:32 am
All antenna connectors are female SMA, so you'll need MALE SMA leads to stick in them. The only exception is the Hi-Z connector on the RSP2 and the Duo, which is a 3-pin type like this: https://www.sdr-kits.net/Hi-Z-Connector-RSP2
cmgam
Postby cmgam » Fri Oct 19, 2018 6:23 pm
Hi
Thanks.
Regards
cmgam
Users browsing this forum: mike0agner and 3 guests
