Earthing outside of F-connector via mains plug?
mikebrock
Postby mikebrock » Wed Dec 09, 2015 12:51 am
Is this method really as simple as it sounds? The way I understand it is you simply crocodile clip the outside of f-connector and run an mains earth wire into an unused mains plug earth pin and plug into household socket??? Seems odd to do that to me - but does it actually work in an sdr set up?
Thoughts please guys - thank you
mike...
Re: Earthing outside of F-connector via mains plug?
Postby jon » Wed Dec 09, 2015 8:49 am
mikebrock wrote:Is this method really as simple as it sounds? The way I understand it is you simply crocodile clip the outside of f-connector and run an mains earth wire into an unused mains plug earth pin and plug into household socket??? Seems odd to do that to me - but does it actually work in an sdr set up?
mike...
Yes, that works, but the ground you achieve is only as good as the mains wiring. If you are on the ground floor, a few metres from the consumer unit for the premises then you may be lucky and truly be a few metres away from a real ohmic connection to the ground. However most likely all you are providing is a random 'counterpoise' to the antenna. This in itself can be very effective but of course your counterpoise is capacitively coupled to the noise-bearing adjacent mains conductors as it wends its way to 'radio' ground. At LF/MW and low HF you may still be providing quite a good radio ground - one rule of thumb is you need to be within a 10th of a wavelength from true ground for your ground to work effectively as a 'ground'. If your radio is in a high-rise building then you are relying a lot on this 'ground' actually being your (very noisy) antenna!
mikebrock
Postby mikebrock » Wed Dec 09, 2015 4:31 pm
Thank you jon for the eye opener and insight into mains ground system as a effective radio ground. Certainly will be trying this out - cheers
mike
