SDRplay support for GNURadio on Windows
JMG
Postby JMG » Tue Oct 18, 2016 9:58 am
I am using the official GNURadio on Windows with the osmosdr plugin, which works with other receivers and supposedly also supports SDRplay.
I already installed the Windows API/hardware driver from sdrplay.com, but osmosdr still doesn't recognize the receiver.
How can I get SDRplay support for GNURadio on Windows (through osmosdr or otherwise)?
John
pa3a
Re: SDRplay support for GNURadio on Windows
Postby pa3a » Fri Jan 13, 2017 1:57 pm
Hi all,
I'm new to SDRplay (and to SDR as well). Anyway, after trying to get GNUradio working SDRplay under windows, I'm still not succesful.
Has this problem been solved?
kind regards,
Arie Kleingeld PA3A
Alexli
Postby Alexli » Fri Feb 03, 2017 6:41 pm
I had the same issue with linux:
Non-Free drivers are not supported by default.
You need to recompile osmosdr with "gr-osmosdr/build$ cmake -DENABLE_NONFREE=TRUE"
However, RSP2 features are not supported at the moment.
Alex
