gr-osmosdr and the RSP2
Alexli
Postby Alexli » Sun Feb 12, 2017 9:21 pm
It's time to adapt the RSP2 to the gr-osmosdr driver.
Doas any body know some attempts here?
The starting point:
https://github.com/krippendorf/gr-osmosdr-fork-sdrplay.git
This works fine and I addet some features:
- Selectable Antenna Ports: "A", "B", "HI-Z"
- 4.7V bias
### Pease forgive me: I am no programmer and do even not really know, what C++ is. ###
The overall osmosdr device arguments: sdrplay=0,lna=0|1,agc-control=0|5|50|100,bias=0|1
Although these features are working well, I am not satisfied:
Even with agc-control=0, I get no stable gain: There seems to be a lack in the relation between the programmed gain and the selected gain.
Could this be because of the gain mode "mir_sdr_USE_SET_GR_ALT_MODE"?
Is there any better explanation of this Mode in the Internet?
I would even like to use LNA=2..8 which is not possible in this mode. Is there a reason for this?
My goal: Using the RSP2 for EMC precompliance measurements.
There are some more questions belong to the gr-osmosdr code - maby someone knows the answer:
- sdrplay_source_c::get_freq_range(size_t chan) :
Where is this function used? I did not port this to RSP2 at the moment.
- sdrplay_source_c::get_devices():
This code is confusig me.
Replace it with something like "mir_sdr_GetDevices(SDR_dev, &cnt, MAX_SUPPORTED_DEVICES);" ?
Is there any concept to support more then one device in the gr-osmosdr?
altogether, the gr-osmosdr code for the sdrplay seems to be a litte bit unstructured and unready...
regards,
file: sdrplay_source_c.cc
/* -*- c++ -*- */
 * Copiright 2016 HB9FXQ, Frank Werner-Krippendorf <mail@hb9fxq.ch>
 * Copyright 2015 SDRplay Ltd <support@sdrplay.com>
 * Copyright 2012 Dimitri Stolnikov <horiz0n@gmx.net>
 * Copyright 2012 Steve Markgraf <steve@steve-m.de>
 * GNU Radio is free software; you can redistribute it and/or modify
 * it under the terms of the GNU General Public License as published by
 * the Free Software Foundation; either version 3, or (at your option)
 * any later version.
 * GNU Radio is distributed in the hope that it will be useful,
 * but WITHOUT ANY WARRANTY; without even the implied warranty of
 * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
 * GNU General Public License for more details.
 * You should have received a copy of the GNU General Public License
 * along with GNU Radio; see the file COPYING.  If not, write to
 * the Free Software Foundation, Inc., 51 Franklin Street,
 * Boston, MA 02110-1301, USA.
 * config.h is generated by configure.  It contains the results
 * of probing for features, options etc.  It should be the first
 * file included in your .cc file.
 * changes by HB9FXQ, 2016:
 * Refactored many parts of the old source, mainly to support more features of the SDR play.
 * Requires the SDRPlay API Version 1.95
 * changes by Alex. Lichte, 2017:
 * Extensions for RSP2: Antenna select (A, B, HI-Z), Bias (4.7V on B), AGC-Default=Off, LNA-Default=ON
 * Requires the SDRPlay API Version 2.09
/* RSP2 LNA State    _dev->lnaEnable
 * Band      0   1   2   3   4   5   6   7   8
 * AM- Band-X   0   10   15   21   24   34   39   45   64(2)
 * Band4/5   0   7   10   17   22   41(2)
 * L Band   0   5   21   15(3)   15(3)   34(2)
 * AM (Port 1)   0   6   12   18   37(2)
 * (1) Mixer GR only
 * (2) Includes LNA GR plus mixer GR
 * (3) In LNAstate 3, external LNA GR only, in LNAstate 4, external plus internal LNA GR
#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
#include "sdrplay_source_c.h"
#include "osmosdr/source.h"
#include <boost/assign.hpp>
#include "arg_helpers.h"
#define MAX_SUPPORTED_DEVICES   4
struct sdrplay_dev {
    int gRdB;
    double gain_dB;
    double fsHz;
    double rfHz;
    mir_sdr_Bw_MHzT bwType;
    mir_sdr_If_kHzT ifType;
    int maxGain;
    int samplesPerPacket;
    int minGain;
    int dcMode;
    int agcSetPoint;
    int gRdBsystem;
    int lnaEnable;
    mir_sdr_AgcControlT agcControl;
    mir_sdr_ReasonForReinitT reinitReson;
    int antenna;
    int antBias;
using namespace boost::assign;
#define BYTES_PER_SAMPLE  4 // sdrplay device delivers 16 bit signed IQ data
// containing 12 bits of information
#define SDRPLAY_AM_MIN     150e3
#define SDRPLAY_AM_MAX      30e6
#define SDRPLAY_FM_MIN      64e6
#define SDRPLAY_FM_MAX     108e6
#define SDRPLAY_B3_MIN     162e6
#define SDRPLAY_B3_MAX     240e6
#define SDRPLAY_B45_MIN    470e6
#define SDRPLAY_B45_MAX    960e6
#define SDRPLAY_L_MIN     1450e6
#define SDRPLAY_L_MAX     1675e6
#define SDRPLAY_MAX_BUF_SIZE 504
#define ANT_A    0
#define ANT_B    1
#define ANT_HI_Z 2
#define DC_ONESHOT 4
#define DC_SPEEDUP_ENABLED 1
 * Create a new instance of sdrplay_source_c and return
 * a boost shared_ptr.  This is effectively the public constructor.
sdrplay_source_c_sptr
make_sdrplay_source_c(const std::string &args) {
    return gnuradio::get_initial_sptr(new sdrplay_source_c(args));
 * Specify constraints on number of input and output streams.
 * This info is used to construct the input and output signatures
 * (2nd & 3rd args to gr::block's constructor).  The input and
 * output signatures are used by the runtime system to
 * check that a valid number and type of inputs and outputs
 * are connected to this block.  In this case, we accept
 * only 0 input and 1 output.
static const int MIN_IN = 0;    // mininum number of input streams
static const int MAX_IN = 0;    // maximum number of input streams
static const int MIN_OUT = 1;    // minimum number of output streams
static const int MAX_OUT = 1;    // maximum number of output streams
std::vector<std::string> AntSel {"A", "B", "HI-Z"};
 * The private constructor
sdrplay_source_c::sdrplay_source_c(const std::string &args)
        : gr::sync_block("sdrplay_source_c",
                         gr::io_signature::make(MIN_IN, MAX_IN, sizeof(gr_complex)),
                         gr::io_signature::make(MIN_OUT, MAX_OUT, sizeof(gr_complex))),
          _running(false),
          _auto_gain(true)
    unsigned int cnt; mir_sdr_DeviceT SDR_dev[MAX_SUPPORTED_DEVICES];
    _dev = (sdrplay_dev_t *) malloc(sizeof(sdrplay_dev_t));
    if (_dev == NULL) {
        return;
      std::cerr << "Program arguments: " << args << std::endl;
    if (cnt)
      std::cerr << "Device found: " << SDR_dev[0].DevNm << std::endl;
    else
      std::cerr << "No Devices found" << std::endl;
        return;
    if (!SDR_dev[0].devAvail)
      std::cerr << "Device bussy" << std::endl; // TODO: Switch to a second device with mir_sdr_SetDeviceIdx(1);
      return;
    _dev->fsHz = 2048e3;
    _dev->rfHz = 96.8e6;
    _dev->bwType = mir_sdr_BW_1_536;
    _dev->ifType = mir_sdr_IF_Zero;
    _dev->dcMode = 0;
    _dev->gRdB = 50;
    _dev->agcSetPoint = -30;
    _dev->lnaEnable = 1;
    _dev->agcControl = mir_sdr_AGC_DISABLE;
    set_gain_limits(_dev->rfHz);
    _dev->gain_dB = _dev->maxGain - _dev->gRdB;
    _dev->antBias = 0;
    _fifo = new boost::circular_buffer<gr_complex>(5000000);
    dict_t dict = params_to_dict(args);
    if (dict.count("sdrplay"))
      if (dict.count("lna"))
        _dev->lnaEnable = (boost::lexical_cast<unsigned int>(dict["lna"]));
        std::cerr << "LNA:  " << _dev->lnaEnable << std::endl;
/*        if (dict.count("lna") && boost::lexical_cast<unsigned int>(dict["lna"])) {
            std::cerr << "LNA switched ON " << std::endl;
        else {
            std::cerr << "LNA switched OFF " << std::endl;
        if (dict.count("agc-control")) {
            unsigned int agcControl = boost::lexical_cast<unsigned int>(dict["agc-control"]);
            if      (agcControl == 0)   _dev->agcControl = mir_sdr_AGC_DISABLE;
            else if (agcControl == 5)   _dev->agcControl = mir_sdr_AGC_5HZ;
            else if (agcControl == 50)  _dev->agcControl = mir_sdr_AGC_50HZ;
            else                        _dev->agcControl = mir_sdr_AGC_100HZ;
            set_gain_mode(_dev->agcControl,0);
            std::cerr << "agcControl " << _dev->agcControl << std::endl;
//        else { _dev->agcControl = mir_sdr_AGC_DISABLE; }
      if (dict.count("bias"))
        _dev->antBias = (boost::lexical_cast<unsigned int>(dict["bias"]));
        std::cerr << "Antenna bias:  " << _dev->antBias << std::endl;
   mir_sdr_RSPII_BiasTControl(_dev->antBias);
    reinit_device();
 * Our virtual destructor.
sdrplay_source_c::~sdrplay_source_c() {
    free(_dev);
    _dev = NULL;
    if (_running) {
        _running = false;
        mir_sdr_StreamUninit();
    if (_fifo) {
        delete _fifo;
        _fifo = NULL;
void sdrplay_source_c::gcCallback(unsigned int gRdB, unsigned int lnaGRdB, void *cbContext) {
    return;
//unsigned long callCnt = 0;
void sdrplay_source_c::streamCallbackStatic(short *xi, short *xq, unsigned int firstSampleNum, int grChanged,
                                            int rfChanged, int fsChanged, unsigned int numSamples, unsigned int reset,
                                            void *cbContext) {
//    // Debugging
//    callCnt++;
//    if (callCnt % 10000 == 0)
//        std::cerr << "streamCalbackStatic: " << callCnt / 10000 << std::endl;
    sdrplay_source_c *obj = (sdrplay_source_c *) cbContext;
    obj->streamCallback(xi, xq, firstSampleNum, grChanged, rfChanged, fsChanged, numSamples, reset);
void sdrplay_source_c::reinit_device() {
    std::cerr << "reinit_device started" << std::endl;
    if (_running) {
        int grMode = 1;
        mir_sdr_Reinit(&_dev->gRdB, _dev->fsHz / 1e6, _dev->rfHz / 1e6, _dev->bwType, _dev->ifType, mir_sdr_LO_Auto,
                       _dev->lnaEnable, &grMode, mir_sdr_USE_SET_GR_ALT_MODE, &_dev->samplesPerPacket, _dev->reinitReson);
    else {
        std::cerr << "before stream init" << std::endl;
        if (_dev->dcMode) {
            std::cerr << "mir_sdr_SetDcMode started" << std::endl;
            mir_sdr_SetDcMode(DC_ONESHOT, DC_SPEEDUP_ENABLED);
        int err = mir_sdr_StreamInit(&_dev->gRdB, _dev->fsHz / 1e6, _dev->rfHz / 1e6, _dev->bwType, _dev->ifType,
                                     _dev->lnaEnable,
                                     &_dev->gRdBsystem,
                                     mir_sdr_USE_SET_GR_ALT_MODE, /* use internal gr tables acording to band */
                                     streamCallbackStatic,
                                     gcCallback, (void *) this);
        if (err != mir_sdr_Success) {
            std::cerr << "StreamInit failed, code " << err << std::endl;
            exit(1);
        _running = true;
        std::cerr << "after stream init: 1" << std::endl;
    std::cerr << "reinit_device end" << std::endl;
void sdrplay_source_c::set_gain_limits(double freq) {
    if (freq <= SDRPLAY_AM_MAX) {
        _dev->minGain = -4;
        _dev->maxGain = 98;
    else if (freq <= SDRPLAY_FM_MAX) {
        _dev->minGain = 1;
        _dev->maxGain = 103;
    else if (freq <= SDRPLAY_B3_MAX) {
        _dev->minGain = 5;
        _dev->maxGain = 107;
    else if (freq <= SDRPLAY_B45_MAX) {
        _dev->minGain = 9;
        _dev->maxGain = 94;
    else if (freq <= SDRPLAY_L_MAX) {
        _dev->minGain = 24;
        _dev->maxGain = 105;
int sdrplay_source_c::work(int noutput_items,
                           gr_vector_const_void_star &input_items,
                           gr_vector_void_star &output_items) {
    gr_complex *out = (gr_complex *) output_items[0];
    boost::unique_lock<boost::mutex> lock(_fifo_lock);
    /* Wait until we have the requested number of samples */
    int n_samples_avail = _fifo->size();
    while (n_samples_avail < noutput_items) {
        _samp_avail.wait(lock);
    for (int i = 0; i < noutput_items; ++i) {
        out[i] = _fifo->at(0);
        _fifo->pop_front();
    return noutput_items;
std::vector<std::string> sdrplay_source_c::get_devices() {
    std::vector<std::string> devices;
    std::cerr << "get_devices started" << std::endl;
    unsigned int dev_cnt = 0;
    mir_sdr_DebugEnable(1);
    /*FIXME: this methods might no longer work in future, look for alternatives... */
    while (mir_sdr_Init(60, 2.048, 200.0, mir_sdr_BW_1_536, mir_sdr_IF_Zero, &samplesPerPacket) == mir_sdr_Success) {
        dev_cnt++;
    std::cerr << "Device count: " << dev_cnt << std::endl;
    for (unsigned int i = 0; i < dev_cnt; i++) {
        mir_sdr_Uninit();
        std::string args = "sdrplay=" + boost::lexical_cast<std::string>(i);
        args += ",label='" + std::string("SDRplay RSP") + "'";
        std::cerr << args << std::endl;
        devices.push_back(args);
    std::cerr << "get_devices end" << std::endl;
    return devices;
size_t sdrplay_source_c::get_num_channels() {
    std::cerr << "get_num_channels: 1" << std::endl;
    return 1;
osmosdr::meta_range_t sdrplay_source_c::get_sample_rates() {
    osmosdr::meta_range_t range;
    range += osmosdr::range_t(2000e3, 12000e3);
    return range;
double sdrplay_source_c::set_sample_rate(double rate) {
    std::cerr << "set_sample_rate start" << std::endl;
    double diff = rate - _dev->fsHz;
    _dev->fsHz = rate;
    std::cerr << "rate = " << rate << std::endl;
    std::cerr << "diff = " << diff << std::endl;
    if (_running) {
        _dev->reinitReson = mir_sdr_CHANGE_FS_FREQ;
        reinit_device();
    std::cerr << "set_sample_rate end" << std::endl;
    return get_sample_rate();
double sdrplay_source_c::get_sample_rate() {
    return _dev->fsHz;
osmosdr::freq_range_t sdrplay_source_c::get_freq_range(size_t chan) {
    osmosdr::freq_range_t range;
    range += osmosdr::range_t(SDRPLAY_AM_MIN, SDRPLAY_AM_MAX); /* LW/MW/SW (150 kHz - 30 MHz) */
    range += osmosdr::range_t(SDRPLAY_FM_MIN, SDRPLAY_FM_MAX); /* VHF Band II (64 - 108 MHz) */
    range += osmosdr::range_t(SDRPLAY_B3_MIN, SDRPLAY_B3_MAX); /* Band III (162 - 240 MHz) */
    range += osmosdr::range_t(SDRPLAY_B45_MIN, SDRPLAY_B45_MAX); /* Band IV/V (470 - 960 MHz) */
    range += osmosdr::range_t(SDRPLAY_L_MIN, SDRPLAY_L_MAX); /* L-Band (1450 - 1675 MHz) */
    return range;
double sdrplay_source_c::set_center_freq(double freq, size_t chan) {
    std::cerr << "set_center_freq start" << std::endl;
    std::cerr << "freq = " << freq << std::endl;
    double diff = freq - _dev->rfHz;
    _dev->rfHz = freq;
    if (_running) {
        _dev->reinitReson = mir_sdr_CHANGE_RF_FREQ;
        reinit_device();
    std::cerr << "set_center_freq end" << std::endl;
    return get_center_freq(chan);
double sdrplay_source_c::get_center_freq(size_t chan) {
    return _dev->rfHz;
double sdrplay_source_c::set_freq_corr(double ppm, size_t chan) {
    return get_freq_corr(chan);
double sdrplay_source_c::get_freq_corr(size_t chan) {
    return 0;
std::vector<std::string> sdrplay_source_c::get_gain_names(size_t chan) {
    std::vector<std::string> gains;
    gains += "LNA_MIX_BB";
    return gains;
osmosdr::gain_range_t sdrplay_source_c::get_gain_range(size_t chan) {
    osmosdr::gain_range_t range;
    for (int i = _dev->minGain; i < _dev->maxGain; i++) {
        range += osmosdr::range_t((float) i);
    return range;
osmosdr::gain_range_t sdrplay_source_c::get_gain_range(const std::string &name, size_t chan) {
    return get_gain_range(chan);
bool sdrplay_source_c::set_gain_mode(bool automatic, size_t chan) {
    std::cerr << "set_gain_mode started" << std::endl;
    _auto_gain = automatic;
    std::cerr << "automatic = " << automatic << std::endl;
    mir_sdr_AgcControl((automatic) ? _dev->agcControl : mir_sdr_AGC_DISABLE, _dev->agcSetPoint, 0, 0, 0, 0, _dev->lnaEnable);
    std::cerr << "set_gain_mode end" << std::endl;
    return get_gain_mode(chan);
bool sdrplay_source_c::get_gain_mode(size_t chan) {
    return _auto_gain;
double sdrplay_source_c::set_gain(double gain, size_t chan) {
    std::cerr << "set_gain started" << std::endl;
    _dev->agcSetPoint = gain;
    std::cerr << "gain = " << gain << std::endl;
    if (gain < _dev->minGain) {
        _dev->gain_dB = _dev->minGain;
    if (gain > _dev->maxGain) {
        _dev->gain_dB = _dev->maxGain;
    _dev->gRdB = (int) (_dev->maxGain - gain);
    if (_running) {
        _dev->reinitReson = mir_sdr_CHANGE_GR;
        std::cerr << "mir_sdr_SetGr started" << std::endl;
        reinit_device();
    std::cerr << "set_gain end" << std::endl;
    return get_gain(chan);
double sdrplay_source_c::set_gain(double gain, const std::string &name, size_t chan) {
    return set_gain(gain, chan);
double sdrplay_source_c::get_gain(size_t chan) {
    return _dev->gain_dB;
double sdrplay_source_c::get_gain(const std::string &name, size_t chan) {
std::vector<std::string> sdrplay_source_c::get_antennas(size_t chan)
   //return {"A", "B", "HI-Z"};
   return AntSel;
std::string sdrplay_source_c::set_antenna(const std::string &antenna, size_t chan) {
   int do_reinit;
   if (antenna == "HI-Z")
     _dev->antenna = ANT_HI_Z;
     mir_sdr_AmPortSelect(1);
     _dev->reinitReson = mir_sdr_CHANGE_AM_PORT;
     sdrplay_source_c::reinit_device();
   else
     if (_dev->antenna == ANT_HI_Z)  do_reinit = 1; else do_reinit = 0;
     if (antenna == "B") { _dev->antenna = ANT_B; mir_sdr_RSPII_AntennaControl(mir_sdr_RSPII_ANTENNA_B);}
     else {_dev->antenna = ANT_A;  mir_sdr_RSPII_AntennaControl(mir_sdr_RSPII_ANTENNA_A);}
     if (do_reinit)
       mir_sdr_AmPortSelect(0);
   std::cerr << "set_antenna = " << AntSel.at(_dev->antenna) << std::endl;
   return get_antenna( chan );
std::string sdrplay_source_c::get_antenna(size_t chan) {
    std::cerr << "get_antenna = " << AntSel.at(_dev->antenna) << std::endl;
    return AntSel.at(_dev->antenna);
void sdrplay_source_c::set_dc_offset_mode(int mode, size_t chan) {
    if (osmosdr::source::DCOffsetOff == mode) {
        _dev->dcMode = 0;
        if (_running) {
    else if (osmosdr::source::DCOffsetManual == mode) {
        std::cerr << "Manual DC correction mode is not implemented." << std::endl;
        _dev->dcMode = 0;
        if (_running) {
    else if (osmosdr::source::DCOffsetAutomatic == mode) {
        _dev->dcMode = 1;
        if (_running) {
void sdrplay_source_c::set_dc_offset(const std::complex<double> &offset, size_t chan) {
double sdrplay_source_c::set_bandwidth(double bandwidth, size_t chan) {
    // default to 1.536
    if (bandwidth <= .1) _dev->bwType = mir_sdr_BW_1_536;
    else if (bandwidth <= 200e3) _dev->bwType = mir_sdr_BW_0_200;
    else if (bandwidth <= 300e3) _dev->bwType = mir_sdr_BW_0_300;
    else if (bandwidth <= 600e3) _dev->bwType = mir_sdr_BW_0_600;
    else if (bandwidth <= 1536e3) _dev->bwType = mir_sdr_BW_1_536;
    else if (bandwidth <= 5000e3) _dev->bwType = mir_sdr_BW_5_000;
    else if (bandwidth <= 6000e3) _dev->bwType = mir_sdr_BW_6_000;
    else if (bandwidth <= 7000e3) _dev->bwType = mir_sdr_BW_7_000;
    else _dev->bwType = mir_sdr_BW_8_000;
    std::cerr << "set_bandwidth" << std::endl;
    if (_running) {
        std::cerr << "set_bandwidth running" << std::endl;
        _dev->reinitReson = mir_sdr_CHANGE_BW_TYPE;
        reinit_device();
    return get_bandwidth(chan);
double sdrplay_source_c::get_bandwidth(size_t chan) {
    double tmpbw = 0.0f;
    if (_dev->bwType == mir_sdr_BW_0_200) tmpbw = 200e3;
    else if (_dev->bwType == mir_sdr_BW_0_300) tmpbw = 300e3;
    else if (_dev->bwType == mir_sdr_BW_0_600) tmpbw = 600e3;
    else if (_dev->bwType == mir_sdr_BW_1_536) tmpbw = 1536e3;
    else if (_dev->bwType == mir_sdr_BW_5_000) tmpbw = 5000e3;
    else if (_dev->bwType == mir_sdr_BW_6_000) tmpbw = 6000e3;
    else if (_dev->bwType == mir_sdr_BW_7_000) tmpbw = 7000e3;
    else tmpbw = 8000e3;
    return (double) tmpbw;
osmosdr::freq_range_t sdrplay_source_c::get_bandwidth_range(size_t chan) {
    range += osmosdr::range_t(200e3);
    range += osmosdr::range_t(300e3);
    range += osmosdr::range_t(600e3);
    range += osmosdr::range_t(1536e3);
    range += osmosdr::range_t(5000e3);
    range += osmosdr::range_t(6000e3);
    range += osmosdr::range_t(7000e3);
    range += osmosdr::range_t(8000e3);
    return range;
//long streamCnt = 0;
void sdrplay_source_c::streamCallback(short *xi, short *xq, unsigned int firstSampleNum, int grChanged, int rfChanged,
                                      int fsChanged, unsigned int numSamples, unsigned int reset) {
//    // Debugging
//    streamCnt++;
//    if (streamCnt % 10000 == 0)
//        std::cerr << "streamCallback: " << streamCnt / 10000 << std::endl;
    size_t i;
    _fifo_lock.lock();
    for (i = 0; i < numSamples; i++) {
        float fI = (float) xi[i] / SHRT_MAX;
        float fQ = (float) xq[i] / SHRT_MAX;
        _fifo->push_back(gr_complex(fI, fQ));
    _fifo_lock.unlock();
    _samp_avail.notify_one();
Alexli
Re: gr-osmosdr and the RSP2
Postby Alexli » Sat Feb 18, 2017 9:41 pm
I bugfix the code at the moment. There is much to do.
Gain control works perfect with mir_sdr_SetGr(_dev->gRdB_in, 1, 0) but I can not set the lnaGrThreshold.
Initialization:
err = mir_sdr_StreamInit(&_dev->gRdB_out, _dev->fsHz / 1e6, _dev->rfHz / 1e6, _dev->bwType, _dev->ifType,
LNAstate,
&_dev->gRdBsystem,
mir_sdr_USE_SET_GR,
Command:
if (mir_sdr_SetGrParams(0,45)) std::cerr << "Settig LNA Treshold failed" << std::endl;
==> Success
Debug Output:
mir_sdr_SetGrParams: gRmin->0 lnaGrThresh->45
However, the treshold remains at 29
API Rev. 2.09, Debian jessie, GNU Radio Companion 3.7.10.1
Test Frequency: 151MHz @ -80dBm
Any idea from the SDRplay Team?
file: sdrplay_source_c.cc:
/* -*- c++ -*- */
 * (1) Mixer GR only
#include "config.h"
#endif
    int gRdB_in;
    int gRdB_out;
    double gain_dB;
    double fsHz;
    double rfHz;
    int maxGain;
    int minGain;
    int dcMode;
    int agcSetPoint;
    int gRdBsystem;
    int lnaTreshold;
    int antenna;
    int antBias;
//typedef struct gcCallbackb gcCallbackb_t;
struct gcCallbackb_t
  unsigned int done; // 1: Callback is ready
  unsigned int gRdB;
  unsigned int lnaGRdB;
  void *cbContext;
gcCallbackb_t *gcCallbackb;
#define ANT_A    0
#define ANT_B    1
#define ANT_HI_Z 2
#define LNA_TRESH_DEF 29
          _running(false),
          _auto_gain(true)
    // unsigned int cnt; mir_sdr_DeviceT SDR_dev[MAX_SUPPORTED_DEVICES];
    if (_dev == NULL) {
        return;
    gcCallbackb = (gcCallbackb_t *) malloc(sizeof(gcCallbackb_t));
    if (gcCallbackb == NULL) {
        return;
/*    mir_sdr_GetDevices(SDR_dev, &cnt, MAX_SUPPORTED_DEVICES);
    if (cnt)
    else
        return;
      return;
    _dev->fsHz = 2e6;
    _dev->dcMode = 0;
    _dev->gRdB_in = 80;
    _dev->lnaTreshold = LNA_TRESH_DEF;
    _dev->gain_dB = _dev->maxGain - _dev->gRdB_in;
    _dev->antBias = 0;
      if (dict.count("lna_tresh"))
        _dev->lnaTreshold = (boost::lexical_cast<unsigned int>(dict["lna_tresh"]));
        std::cerr << "LNA Treshold:  " << _dev->lnaTreshold << std::endl;
    _dev->reinitReson = (mir_sdr_ReasonForReinitT)0x7F;
    reinit_device();
//    set_bandwidth(mir_sdr_BW_1_536,0);  // beter to reinit again ...
    if (_dev->antBias) mir_sdr_RSPII_BiasTControl(_dev->antBias);  // better to call after init...
    if(_dev->lnaTreshold != LNA_TRESH_DEF)
      if (mir_sdr_SetGrParams(0,_dev->lnaTreshold)) std::cerr << "Settig LNA Treshold failed" << std::endl;
    free(_dev);
    _dev = NULL;
    if (_running) {
        _running = false;
    if (_fifo) {
        delete _fifo;
        _fifo = NULL;
    std::cerr << "### gcCallback ### gRdB:  " << gRdB << "  lnaGRdB: " << lnaGRdB << "  cbContext: " << cbContext << std::endl;
    gcCallbackb->done = 1;
    gcCallbackb->gRdB = gRdB;
    gcCallbackb->lnaGRdB = lnaGRdB;
    gcCallbackb->cbContext = cbContext;
    return;
                                            void *cbContext) {
//    // Debugging
//    callCnt++;
    int err, LNAstate=1;
    std::cerr << "reinit_device started. Reason: 0x"  << std::hex << _dev->reinitReson << std::dec << "  gRdB: " << _dev->gRdB_in << std::endl;
    if (_running)
      _dev->gRdB_out = _dev->gRdB_in;
      err = mir_sdr_Reinit(&_dev->gRdB_out, _dev->fsHz / 1e6, _dev->rfHz / 1e6, _dev->bwType, _dev->ifType, mir_sdr_LO_Auto,
                     LNAstate, &_dev->gRdBsystem, mir_sdr_USE_SET_GR, &_dev->samplesPerPacket, _dev->reinitReson);
         std::cerr << "ReInit failed, code " << err << "  gRdB: " << _dev->gRdB_in  << "  gRdBsystem: " <<  _dev->gRdBsystem   << "  reinitReson: " << _dev->reinitReson  << std::endl;
    else
      if (_dev->dcMode)
                                     LNAstate,
                                     &_dev->gRdBsystem,
                                     mir_sdr_USE_SET_GR,
         return;
      _running = true;
    usleep(1000);
    mir_sdr_ResetUpdateFlags(1,1,1);
    std::cerr << "reinit_device end - gainVals.current: " << _dev->gRdB_out << std::endl;
  int err;
  mir_sdr_GainValuesT limits;
  err=mir_sdr_GetCurrentGain(&limits);
  _dev->maxGain = (int)limits.max;
  _dev->minGain = (int)limits.min;
    _dev->minGain = 20;
    _dev->maxGain = 70;
  std::cerr << "Gain:  error: " << err <<  "  min: " << _dev->minGain << "  max: " <<  _dev->maxGain << std::endl;
        _fifo->pop_front();
    unsigned int i, cnt; mir_sdr_DeviceT SDR_dev[MAX_SUPPORTED_DEVICES];
    for(i=0; i<MAX_SUPPORTED_DEVICES; i++)
      if (cnt)
        std::cerr << "Device found: " << SDR_dev[i].DevNm << std::endl;
        if (SDR_dev[i].devAvail)
     dev_cnt++;
        else std::cerr << "Device bussy" << std::endl;
        cnt--;
    if (!dev_cnt)
      std::cerr << "No Devices available" << std::endl;
    return devices;
    return 1;
    return range;
    _dev->fsHz = rate;
    if (_running) {
        reinit_device();
    return _dev->fsHz;
    return range;
    _dev->rfHz = freq;
    if (_running) {
        _dev->reinitReson = (mir_sdr_ReasonForReinitT)(mir_sdr_CHANGE_RF_FREQ/*|mir_sdr_CHANGE_GR*/);
        gcCallbackb->done = 0;
        reinit_device();
    return _dev->rfHz;
    return 0;
    return gains;
    return range;
    int LNAstate=1;
    mir_sdr_AgcControl((automatic) ? _dev->agcControl : mir_sdr_AGC_DISABLE, _dev->agcSetPoint, 0, 0, 0, 0, LNAstate);
    return _auto_gain;
    } else
    } else _dev->gain_dB = gain;
    std::cerr << "gain = " << _dev->gain_dB << std::endl;
    _dev->gRdB_in = (int) (_dev->maxGain - _dev->gain_dB);
    if (_running)
      mir_sdr_SetGr(_dev->gRdB_in, 1, 0);
/*      _dev->reinitReson = (mir_sdr_ReasonForReinitT)(mir_sdr_CHANGE_GR|mir_sdr_CHANGE_BW_TYPE  );
      std::cerr << "mir_sdr_SetGr started with gRdB (maxGain - gain): " << _dev->gRdB_in << std::endl;
      reinit_device();
   return AntSel;
   int do_reinit;
   else
     if (do_reinit)
        _dev->dcMode = 0;
        if (_running) {
        _dev->dcMode = 0;
        if (_running) {
        _dev->dcMode = 1;
        std::cerr << "DC correction enabled" << std::endl;
        if (_running) {
    // default to 1.536
    if (_running) {
        reinit_device();
   set_gain(get_gain(0));
    return range;
//    // Debugging
//    streamCnt++;
    size_t i;
    _fifo_lock.lock();
