SoapySDDRPlay on Raspberry Pi - libusb error
DVE
Postby DVE » Sat Sep 09, 2017 1:36 pm
Hi all,
I'm trying to run SoapySDRPlay on RPi, and getting this:
1) SoapySDRUtil --info
Lib Version: v0.6.1-g285e72aa
API Version: v0.6.0
ABI Version: v0.6
Install root: /usr/local
Search path: /usr/local/lib/SoapySDR/modules0.6
Module found: /usr/local/lib/SoapySDR/modules0.6/libsdrPlaySupport.so
Loading modules... done
Available factories...null, sdrplay
2) SoapySDRUtil --probe
Probe device
SoapySDRUtil: symbol lookup error: /usr/local/lib/libmirsdrapi-rsp.so.2.10: undefined symbol: libusb_get_port_number
So, nothing works.
libusb-1.0-0-dev is already installed.
Any ideas?
Thanks.
Re: SoapySDDRPlay on Raspberry Pi - libusb error
Postby sdrplay » Tue Sep 12, 2017 12:08 am
That sounds like something has updated libusb beyond the build that is released on the RPi image (unless it's been updated recently?). Have you tried re-running the RPi API installer?
Is your starting point our RPi image download or have you used a stock OS image - iss it Raspbian?
DVE
Postby DVE » Tue Sep 12, 2017 12:47 pm
Thanks for the answer.
I'm using standard OS image on RPi2 (maybe RPi3 only supported?).
Will reinstall all and try again today evening.
DVE
Postby DVE » Tue Sep 12, 2017 7:20 pm
I tested it again on the second RPi.
New Raspberry Pi3 - all works ok. Don't know yet why it does not work on RPi2 though. Maybe it makes sense to do clean install and rebuild all stuff again.
Postby sdrplay » Sun Sep 17, 2017 7:49 am
You could try building/installing libusb 1.0.19 or libusb 1.0.20 from http://libusb.info/
