rtl_power for SDRPlay?
Toontje
Postby Toontje » Sat Jul 07, 2018 12:55 pm
Does anyone know of an rtl_power or similar implementation for SDRPlay?
Ton.
Sasan
Re: rtl_power for SDRPlay?
Postby Sasan » Sun Jul 08, 2018 11:38 am
Have you checked rx_tools?
https://github.com/rxseger/rx_tools
(relies on SoapySDR)
DF2HF, NM9A, EP2C
Toontje
Postby Toontje » Mon Jul 30, 2018 10:42 am
nice!! Exactly what i was looking for.
Thanks!!
Toontje
Postby Toontje » Sun Nov 04, 2018 12:42 pm
So rx_tools worked great on the SRP1. When using rx_power on the RSP1A i get the following:
Error: bad retune at 88500000 Hz (4 of 3 attempts), r=-5, flags=0 (try increasing -S or -R).
Error: reading stream -5
Any ideas?
Sasan
Postby Sasan » Sun Nov 04, 2018 9:05 pm
Toontje wrote:So rx_tools worked great on the SRP1. When using rx_power on the RSP1A i get the following:
Any ideas?
have you tried increasing the retry via -R switch ?
DF2HF, NM9A, EP2C
Toontje
Postby Toontje » Thu Nov 08, 2018 1:04 pm
Yes, i did. No change.
Users browsing this forum: sq5bpf and 2 guests
