Windows API
SDR
Windows API
Post by SDR » Fri Oct 30, 2015 1:37 am
I'm trying to use the windows API to control the SDRPlay. I'm calling the dll with Labview. I have the version call working, it returns the version of 1.7. Then I call the initialize function and it returns a 0 so all apears well. Then when I call the read function it returns a 10 which is saying that it is not initialized. The error codes are conflicting so at this point I'm not sure if the problem is with the init or read. Has anyone else used the API or had problems using it.
Mike
Re: Windows API
Post by sdrplay » Fri Oct 30, 2015 8:03 am
Hi SDR,
If you follow the sequencing shown in the example code at the bottom of the API specification document then you should be ok. If you can send screenshots or a code sample to support@sdrplay.com we'd be happy to help you get this resolved.
angazu
Re: Windows API
Post by angazu » Fri Nov 27, 2015 9:08 pm
Hi all.
I am interested in SDRplay control from Labview, but I am not an experienced programmer.
Can you be so polite to share source code to play with?
Thanks a lot.
ANgazu.
