SDRPLAY with tetra decoder
fe8769
Postby fe8769 » Mon Dec 21, 2015 11:09 am
Hello
If someone could solve tetra decoding software .
project used :
https://github.com/sq5bpf
Command line used :
#!/bin/sh
export TETRA_HACK_PORT=7379
export TETRA_HACK_RXID=$1
ulimit -c unlimited
./osmo-tetra-sq5bpf/src/demod/python/osmosdr-tetra_demod_fft.py -a sdrplay -o /dev/stdout | ./osmo-tetra-sq5bpf/src/float_to_bits /dev/stdin /dev/stdout | ./osmo-tetra-sq5bpf/src/tetra-rx /dev/stdin
This command is working well with RTL SDR and should work with SDRPLAY
Linux is Xubuntu 14.04
detail of osmosdr-tetra_demod_fft.py (main working program)
#!/usr/bin/env python
# Copyright 2012 Dimitri Stolnikov <horiz0n@gmx.net>
# Usage:
# src$ ./demod/python/osmosdr-tetra_demod_fft.py -o /dev/stdout | ./float_to_bits /dev/stdin /dev/stdout | ./tetra-rx /dev/stdin
# Adjust the center frequency (-f) and gain (-g) according to your needs.
# Use left click in Wideband Spectrum window to roughly select a TETRA carrier.
# In Wideband Spectrum you can also tune by 1/4 of the bandwidth by clicking on the rightmost/leftmost spectrum side.
# Use left click in Channel Spectrum windows to fine tune the carrier by clicking on the left or right side of the spectrum.
import sys
import math
from gnuradio import gr, gru, eng_notation, blocks, filter
from gnuradio.filter import pfb
from gnuradio.eng_option import eng_option
from gnuradio.wxgui import fftsink2, scopesink2, forms, TRIG_MODE_AUTO
from grc_gnuradio import wxgui as grc_wxgui
from optparse import OptionParser
import osmosdr
import wx
try:
import cqpsk
except:
from tetra_demod import cqpsk
# applies frequency translation, resampling and demodulation
class top_block(grc_wxgui.top_block_gui):
def __init__(self):
grc_wxgui.top_block_gui.__init__(self, title="Top Block")
options = get_options()
self.ifreq = options.frequency
self.rfgain = options.gain
self.src = osmosdr.source(options.args)
self.src.set_center_freq(self.ifreq)
self.src.set_sample_rate(int(options.sample_rate))
if self.rfgain is None:
self.src.set_gain_mode(1)
self.iagc = 1
self.rfgain = 0
else:
self.iagc = 0
self.src.set_gain_mode(0)
self.src.set_gain(self.rfgain)
# may differ from the requested rate
sample_rate = self.src.get_sample_rate()
sys.stderr.write("sample rate: %d\n" % (sample_rate))
symbol_rate = 18000
sps = 2 # output rate will be 36,000
out_sample_rate = symbol_rate * sps
options.low_pass = options.low_pass / 2.0
if sample_rate == 96000: # FunCube Dongle
first_decim = 2
else:
first_decim = 10
self.offset = 0
taps = filter.firdes.low_pass(1.0, sample_rate, options.low_pass, options.low_pass * 0.2, filter.firdes.WIN_HANN)
self.tuner = filter.freq_xlating_fir_filter_ccf(first_decim, taps, self.offset, sample_rate)
self.demod = cqpsk.cqpsk_demod(
samples_per_symbol = sps,
excess_bw=0.35,
costas_alpha=0.03,
gain_mu=0.05,
mu=0.05,
omega_relative_limit=0.05,
log=options.log,
verbose=options.verbose)
self.output = blocks.file_sink(gr.sizeof_float, options.output_file)
rerate = float(sample_rate / float(first_decim)) / float(out_sample_rate)
sys.stderr.write("resampling factor: %f\n" % rerate)
if rerate.is_integer():
sys.stderr.write("using pfb decimator\n")
self.resamp = pfb.decimator_ccf(int(rerate))
else:
sys.stderr.write("using pfb resampler\n")
self.resamp = pfb.arb_resampler_ccf(1 / rerate)
self.connect(self.src, self.tuner, self.resamp, self.demod, self.output)
self.Main = wx.Notebook(self.GetWin(), style=wx.NB_TOP)
self.Main.AddPage(grc_wxgui.Panel(self.Main), "Wideband Spectrum")
self.Main.AddPage(grc_wxgui.Panel(self.Main), "Channel Spectrum")
self.Main.AddPage(grc_wxgui.Panel(self.Main), "Soft Bits")
def set_ifreq(ifreq):
self.ifreq = ifreq
self._ifreq_text_box.set_value(self.ifreq)
self._ifreq_text_box = forms.text_box(
parent=self.GetWin(),
value=self.ifreq,
callback=set_ifreq,
label="Center Frequency",
converter=forms.float_converter(),
self.Add(self._ifreq_text_box)
def set_iagc(iagc):
self.iagc = iagc
self._agc_check_box.set_value(self.iagc)
self.src.set_gain_mode(self.iagc, 0)
self.src.set_gain(0 if self.iagc == 1 else self.rfgain, 0)
self._agc_check_box = forms.check_box(
value=self.iagc,
callback=set_iagc,
label="Automatic Gain",
true=1,
false=0,
self.Add(self._agc_check_box)
def set_rfgain(rfgain):
self.rfgain = rfgain
self._rfgain_slider.set_value(self.rfgain)
self._rfgain_text_box.set_value(self.rfgain)
_rfgain_sizer = wx.BoxSizer(wx.VERTICAL)
self._rfgain_text_box = forms.text_box(
sizer=_rfgain_sizer,
value=self.rfgain,
callback=set_rfgain,
label="RF Gain",
proportion=0,
self._rfgain_slider = forms.slider(
value=self.rfgain,
minimum=0,
maximum=50,
num_steps=200,
style=wx.SL_HORIZONTAL,
cast=float,
proportion=1,
self.Add(_rfgain_sizer)
self.Add(self.Main)
def fftsink2_callback(x, y):
if abs(x / (sample_rate / 2)) > 0.9:
set_ifreq(self.ifreq + x / 2)
else:
sys.stderr.write("coarse tuned to: %d Hz\n" % x)
self.offset = x
self.tuner.set_center_freq(self.offset)
self.scope = fftsink2.fft_sink_c(self.Main.GetPage(0).GetWin(),
title="Wideband Spectrum (click to coarse tune)",
fft_size=1024,
sample_rate=sample_rate,
ref_scale=2.0,
ref_level=0,
y_divs=10,
fft_rate=10,
average=False,
avg_alpha=0.6)
self.Main.GetPage(0).Add(self.scope.win)
self.scope.set_callback(fftsink2_callback)
self.connect(self.src, self.scope)
def fftsink2_callback2(x, y):
self.offset = self.offset - (x / 10)
sys.stderr.write("fine tuned to: %d Hz\n" % self.offset)
self.scope2 = fftsink2.fft_sink_c(self.Main.GetPage(1).GetWin(),
title="Channel Spectrum (click to fine tune)",
fft_size=1024,
sample_rate=out_sample_rate,
ref_scale=2.0,
ref_level=-20,
y_divs=10,
fft_rate=10,
average=False,
avg_alpha=0.6)
self.Main.GetPage(1).Add(self.scope2.win)
self.scope2.set_callback(fftsink2_callback2)
self.connect(self.resamp, self.scope2)
self.scope3 = scopesink2.scope_sink_f(
self.Main.GetPage(2).GetWin(),
title="Soft Bits",
v_scale=0,
v_offset=0,
t_scale=0.001,
ac_couple=False,
xy_mode=False,
num_inputs=1,
trig_mode=TRIG_MODE_AUTO,
y_axis_label="Counts",
self.Main.GetPage(2).Add(self.scope3.win)
self.connect(self.demod, self.scope3)
def get_options():
parser = OptionParser(option_class=eng_option)
parser.add_option("-a", "--args", type="string", default="",
help="gr-osmosdr device arguments")
parser.add_option("-s", "--sample-rate", type="eng_float", default=1800000,
help="set receiver sample rate (default 1800000)")
parser.add_option("-f", "--frequency", type="eng_float", default=394.4e6,
help="set receiver center frequency")
parser.add_option("-g", "--gain", type="eng_float", default=None,
help="set receiver gain")
# demodulator related settings
parser.add_option("-l", "--log", action="store_true", default=False, help="dump debug .dat files")
parser.add_option("-L", "--low-pass", type="eng_float", default=25e3, help="low pass cut-off", metavar="Hz")
parser.add_option("-o", "--output-file", type="string", default="out.float", help="specify the bit output file")
parser.add_option("-v", "--verbose", action="store_true", default=False, help="dump demodulation data")
(options, args) = parser.parse_args()
if len(args) != 0:
parser.print_help()
raise SystemExit, 1
return (options)
if __name__ == '__main__':
tb = top_block()
tb.Run(True)
end of code
error running software :
./sdrplay.sh
gr-osmosdr v0.1.4-48-g86ad5842 (0.1.5git) gnuradio 3.7.8.1
built-in source types: file fcd rtl rtl_tcp uhd hackrf bladerf rfspace airspy
FATAL: No supported devices found to pick from.
Trying to fill up 1 missing channel(s) with null source(s).
This is being done to prevent the application from crashing
due to gnuradio bug #528.
sample rate: 0
Traceback (most recent call last):
File "./osmo-tetra-sq5bpf/src/demod/python/osmosdr-tetra_demod_fft.py", line 254, in <module>
tb = top_block()
File "./osmo-tetra-sq5bpf/src/demod/python/osmosdr-tetra_demod_fft.py", line 71, in __init__
File "/usr/local/lib/python2.7/dist-packages/gnuradio/filter/filter_swig.py", line 126, in low_pass
return _filter_swig.firdes_low_pass(*args, **kwargs)
RuntimeError: firdes check failed: sampling_freq > 0
Thanks for answer
fe8769
Re: SDRPLAY with tetra decoder
Postby fe8769 » Mon Dec 21, 2015 7:34 pm
I found solution by myself (like often)
I rebuild gr-osmosdr with cmake -DENABLE_NONFREE=TRUE ..\
Sdrplay is decoding TETRA
fe8769
Postby fe8769 » Mon Mar 21, 2016 10:41 pm
Concerning Tetra decoding , what does "lost sample" means with osmosdr source ?
Postby 0815 » Sat Apr 02, 2016 3:29 pm
i suggest the pc/notebook is a bit too slow......
regards
bilbolodz
Postby bilbolodz » Wed May 11, 2016 9:20 pm
fe8769 wrote:Sdrplay is decoding TETRA
Have you changed anything in grc file? Please tell me your values for"SDR Input Gain" and "SDR IF Gain". I successfully manged decode Tetra on RTL USB stick but NOT on sdrplay.......
