New API
va2fsq
New API
Postby va2fsq » Sun Jul 17, 2016 6:03 pm
I thought that the new API would support sampling rates lower than 2,000,000 samples per second.
It works at 600,000 but no lower. Is it not possible for you to do this without requiring using the downconvert function?
Re: New API
Postby sdrplay » Mon Jul 18, 2016 1:46 pm
Yes, in Zero IF mode you can go as low as the IF Bandwidth you have selected by using the mir_sdr_DecimateControl function.
So for example if you specify 200kHz IF bandwidth, then specify 2MHz sample rate. After your mir_sdr_StreamInit call, use...
mir_sdr_DecimateControl(1, 4, 0);
1 = enable, 4 = decimation factor - this will produce a final sample rate in this case of 250kHz
If Low IF mode, there are only 4 cases that are supported and they are listed in the API specification.
Hope that helps,
