Sample Rate to 3-4-5- ..... Mhz
Since I used my SDRplay as a pan adapter for my FTdx5000 I can not set the Sample Rate to 3-4-5- etc. Mhz anymore.
Only 2 and 8,192 can I select.
What have I forgotten?
Re: Sample Rate to 3-4-5- ..... Mhz
This is because you have put your device in low IF mode and in Low IF mode, these are the only sample rates available. Open up the Settings Panel (SETT button on the main panel) and select Zero IF mode and you will be able to set up to 10 MHz sample rate again.
What can life be easy if you are getting a little help.
Thanks for the quick reply.
