RSP1a only noise
Post your feedback here
Johntk56
RSP1a only noise
Post by Johntk56 » Fri Jun 22, 2018 3:26 pm
I am the happy owner of a new RSP1a :D
- switched from a noname RTL dongle which worked perfect
My problem is that all I have is noise
- even nearby FM stations cannot be heard
Reinstalled SDRuno 1.22 three times
Probably in settings - but where :?:
/ John
Re: RSP1a only noise
Post by g1hbe » Fri Jun 22, 2018 4:58 pm
If you could post a picture of your screen we may be able to spot the problem.
mark.
Post by mark. » Sat Jun 23, 2018 3:26 am
Also screw your antenna into another radio to make sure the antenna,cable and connectors are good.
Johntk56
Post by Johntk56 » Sat Jun 23, 2018 10:01 pm
Have tested the antenna with another receiver and it is OK
The receiver works perfect with HDSDR
- screendump attached
/ John
Post by Tech_Support » Sun Jun 24, 2018 5:25 am
Hello John,
You are tuned to 107.2 kHz, not 107.2 MHz.
Johntk56
Post by Johntk56 » Sun Jun 24, 2018 7:48 am
Nice sunday morning here in Denmark
- and tuned to the correct freqency it all works very well :oops:
Thanks, and have a nice day :D
/ John
