RSPduo and other software
Roger
Re: RSPduo and other software
Post by Roger » Sun Sep 16, 2018 9:29 pm
Conrad Farlow wrote:Is the dual tuner mode guaranteed to be coherent and can I stream 2 pairs of coherent IQ data?
The dual tuners are capable of being time coherent but they are not in the present software (SDRuno v 1.24) . IQ streaming is planned for a future version. SDRplay does not give release dates for software so we will have to wait.....
Conrad Farlow
Post by Conrad Farlow » Sun Sep 16, 2018 9:35 pm
Hello Roger.
Then SDRplay will have to wait for my cash :-)
Do you know if the ExtIo allows coherent operation and whether or not the HDSDR implementation allows IQ streaming of all 4 channels?
Regards
Conrad PA5Y
Roger
Post by Roger » Mon Sep 17, 2018 7:46 pm
Conrad Farlow wrote:Hello Roger.
No the RSPduo Extio.dll does not support coherent support of both tuners. HDSDR does have IQ streaming but only of one tuner at a time.
bluesheep
Post by bluesheep » Mon Sep 24, 2018 3:20 pm
_____________________________________________________________________
I am surprised. If I am reading the above correctly, the whole reason I bought the RSPduo is delayed until some, unspecified, future date. I never saw this "detail" on the SDRplay web site nor in the SDRuno manual. Rather I saw the ability to do phase coherent, diversity reception touted as a feature. I was wondering how the LO's could be different and still phase locked. I made sure the LO's were the same and locked them, but I guess I was wrong in the assumption they were phase locked. I have encouraged others to buy this receiver for coherent diversity reception, now I have to give them the happy news...
Post by Tech_Support » Mon Sep 24, 2018 5:18 pm
Hello Bluesheep,
There seems to be a bit of confusion here. The two tuners in the RSPduo both run off a common reference clock and so if tuned to the same frequency, both tuners will be phase locked and I/Q streams are time aligned. However, because as things currently stand, the two tuners (to operate simultaneously) have to operate in separate instances of SDRuno, then as the instances cannot be started simultaneously, buffering means that the audio for the two tuners will not be time aligned between the separate instances of SDRuno.
The solution to this will be when we release a version of SDRuno that can process both I/Q streams within a single instance and this will allow us to perform diversity and noise cancellation. This is currently scheduled for release 1.4 of SDRuno which will be the release after 1.3 which is currently in development.
We already have customers who (under Linux) have developed their own noise cancellation software using the RSPduo and our current service based API and so we know that the technology works just fine.
We cannot give a schedule for release 1.4 as there is still a lot of development work on-going for release 1.3 which includes a range of long promised features such as scanning, moving registry settings to a .INI file, piping I/Q audio to VAC etc.
I hope this clears up any confusion.
Conrad Farlow
Post by Conrad Farlow » Thu Jan 17, 2019 5:50 pm
Personally I would just like to see an ExtIO that has a mode to lock the two receivers and produce 2 coherent streams that can be used with Linrad and MAP65. There are a number of EME operators that would find this useful. This would not take as much effort as a major software release and would satisfy a need.
73
Conrad PA5Y
