Shorting aerial OK?
Shorting aerial OK?
Is it ok to put a dead short across the aerial input to protect it from static and nearby HF transmissions when it's not in use?
Re: Shorting aerial OK?
Is everyone on holiday?
Dear m0phe,
Applying a short to the antenna will not cause any problems with the RSP as there is no DC bias on the antenna port.
Thank very much!
