Issues with Windows 10 for workstations...
S79RP
Postby S79RP » Tue Nov 27, 2018 9:32 am
Hello Guys, just facing a problem with new laptop and SDRuno... after installing, when trying to run the program it doesnt detect the RSPDuo.
I see at device manager windows says can not load the driver: "Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)
{Bad Image}
%hs is either not designed to run on Windows or it contains an error. Try installing the program again using the original installation media or contact your system administrator or the software vendor for support. Error status 0x"
Any suggestions welcome!
PC details: DELL precision 7530, XEON CPU, 32 Gb RAM, SSD 500GB...OS Windows 10 for workstations
GrumpyCyborg
Re: Issues with Windows 10 for workstations...
Postby GrumpyCyborg » Sun Dec 30, 2018 11:04 am
Remove the device from device manager (right click) install the drivers and then plug it back in.
Good Luck.
Last edited by GrumpyCyborg on Thu Jan 01, 1970 12:00 am, edited 0 times in total.
Postby Paul » Sun Dec 30, 2018 3:49 pm
Be sure not to plug the RSP in during installation until prompted to do so. It seems that this may be a frequently made error and is likely to result in the issue that you have experienced.
vsonnier
Postby vsonnier » Wed Jan 02, 2019 5:32 am
Auto-qutote, see:
viewtopic.php?f=7&t=3553
