Move time marker to right side of spectrum.
JayDubya
Post by JayDubya » Sun Dec 16, 2018 3:15 pm
I did a search here and in the manual for 'time markers' but found nothing.
I think it would be great to move the time markers -or- the DB scale to the right side of the spectrum display. With them both on the same side it makes it hard to see the time info.
Or did I miss something in the manual again?
Re: Move time marker to right side of spectrum.
Post by sdrplay » Mon Jan 07, 2019 11:34 am
Hi JayDubya,
Can you show a screenshot showing the problem?
The time markers are in the waterfall, not the spectrum display - unless you use the Combo option, in which case they will overlap. Using either SP, WF or SP + WF modes should not have this problem.
JayDubya
Post by JayDubya » Mon Jan 07, 2019 12:59 pm
Yes I should have specified the Combo mode.... even so it would be real helpful to be able to swap sides. Don't see any way to upload the picture of interest without going through a bunch of pushups. Be glad to e-mail it to you.
Basically I needed to monitor an STL transmitter and its neighbors over a long period of time to try and detect a dropout and the combo screen provided the best representation of all the info.
Post by sdrplay » Mon Jan 07, 2019 1:16 pm
You can send it to me here - software at sdrplay.com
Post by sdrplay » Mon Jan 07, 2019 1:17 pm
btw if you are monitoring a single frequency, have you tried the power/snr to csv function?
Post by sdrplay » Mon Jan 07, 2019 1:59 pm
Thanks for the email and the image - I can see how having the option to move the time stamp to the right would make the use of Combo mode much clearer.
I'll just need to work out when I can get that change in. Thanks for the feedback.
