RSP1A will not connect on boot up
cmsnow
Postby cmsnow » Fri Jan 11, 2019 6:29 pm
My RSP1A will not connect on PC boot up. However, after boot up, if I unplug it and plug it back in it will connect and everything works fine. On boot up, it seems to be an unidentified USB device. After unplug/plug it appears under Sound, video and game controllers
Suggestions?
Re: RSP1A will not connect on boot up
Postby Mike2459 » Fri Jan 11, 2019 8:25 pm
I have had this happen when standby power was turned off. Standby power is off when the power supply switch is turned off or if line power is removed.
cmsnow
Postby cmsnow » Fri Jan 11, 2019 9:20 pm
Mike2459 wrote:I have had this happen when standby power was turned off. Standby power is off when the power supply switch is turned off or if line power is removed.
OK, mine is similar. I turn on the PC from an external power switch. So all power is off before initial boot up.
Now what? SDRPlay engineers, why would it do this and how to fix it?
Users browsing this forum: Andy.B and 10 guests
