FILTER CHEBYSHEV HIGH PASS N=9 - 50/50 Ohm - UNBALANCED
From prototype to finished filter
The filter is built on a one side PC board used as a soldering reference ground plane for minimising parasitic inductances. All components are assembled on this board prior to mounting inside the die cast enclosure. I was worried about parasitic coupling among the coils, due to close proximity, but filter attenuation @ 1.5 MHz is very similar to that of the original prototype (#6) so this problem did not materialise. Another worry was what would happen with closing the lid, but no detrimental IN/OUT coupling was detected.
Coil formers were made with 20 mm dia. PVC electrical conduit pipe and no detrimental effects on coil Q was detected. Once the filter is mounted inside the enclosure and tested, it is advisable to glue the base of each coil former to the PC board with bi-component epoxy resin.
Later today antenna attenuation of LW and MW band will be tested on the RSPduo and reported.
- Chebyshev N=9 HI PASS FILTER DATA.jpg (106.49 KiB) Viewed 3804 times
- DSC_1405.JPG (73.25 KiB) Viewed 3804 times
- DSC_1404.JPG (69.49 KiB) Viewed 3804 times
Practical results
Practical results
- HP filter in operation.JPG (75.92 KiB) Viewed 3800 times
- No HP Filter MW broadcast Band.jpg (264.92 KiB) Viewed 3801 times
- HP Filter in MW broadcast band.jpg (262.72 KiB) Viewed 3801 times
Practical results
NOTE: For the measurements of previous post and of this one there is a 550 to 50 Ohm toroid transformer between Beverage antenna & filter's input.
Practical results
- While @ 3.6 MHz is business as usual....jpg (191.62 KiB) Viewed 3776 times
- Spectrum 0-1500 KHz - No HP filter.jpg (192.99 KiB) Viewed 3778 times
- Spectrum 0-1500 KHz with HP filter.jpg (179.73 KiB) Viewed 3778 times
Filter performance near cutoff with Network Analyser- 1
- Measurement setup with AA30 Network Analyser
- Measurement setup.JPG (152.49 KiB) Viewed 3743 times
- Return loss near the 2 MHz cutoff frequency better than 12 dB
- HIGH PASS R.L. 1-3MHz.jpg (113.86 KiB) Viewed 3743 times
- SWR near the 2 MHz cutoff frequency 1.6 max.
- HIGH PASS SWR 1-3 MHz.jpg (65.35 KiB) Viewed 3743 times
Filter performance 2 to 10 & 2 to 29 MHz with Network Analyser- 2
- HIGH PASS SWR 1-10 MHz.jpg (67.37 KiB) Viewed 3719 times
- HIGH PASS SWR 1-29 MHz.jpg (67.62 KiB) Viewed 3719 times
- HIGH PASS R.L. 1-29 MHz.jpg (64.44 KiB) Viewed 3719 times
Responding to the original post of the thread..
For the one scenario I didn't see, 500 ohm longwire and 50 ohm radio.
Would I build a 500 in/500 out filter with a 500/50 transformer on the output of the filter or a 50/50 filter with a 500/50 transformer on the input of the filter? Or can it be done through filter values and no transformers?
Hi Mark,
In the last posts I have finalised construction and performance measurements for the 50 Ohm to 50 Ohm filter. This filter is useful for connecting a 50 Ohm antenna feedline to a 50 Ohm input of the RSP receiver. If you wish you can place a 10:1 low noise transformer at the filter's input (560 to 50 Ohm) and connect through the filter a long wire antenna to the 50 Ohm input of the RSP receiver.
Two days ago I have started the construction of the Chebyshev filter N=9, r=1.5 dB, ZIN/ZOUT=0.6 - PROTOTYPE #7: this filter had been designed for connecting directly a 600 Ohm long wire antenna to the 1 KOhm Hi Z balanced input of the RSP2 or the RSPduo. Unfortunately I have found that the coils developed for the prototype (prototype #7) are too large and do not fit in the 1590 BS Hammond die cast enclosure I have purchased. Furthermore I have found, measuring prototype #7 with the Network Analyser, that SWR becomes too high past 4 MHz and this problem is caused by the 0.6:1 ratio between input and output. For this reason I have re-designed the filter for a 1:1 ratio, eg. 560 to 560 Ohm. This filter will connect to the long wire antenna directly and will have at the output a 1:2 ratio wideband, low noise transformer matching the 1 KOhm HI Z input of the RSP receiver. By changing this transformer, e.g. using a 10:1 ratio, 560 to 50 Ohm, it will be possible to couple a long wire antenna to a 50 Ohm input.
For the practical realisation of this filter I need smaller coils. I tested iron powder toroid coils made with type 1 material, e.g. Micrometals T50-1, but Q is too low: Q<120 @ 2 Mhz. So I have developed a new layout with air core coils (Q=200) and am presently building the filter which will fit into the box. I expect to be ready for measurements and do them over the weekend. I also inted to write a post dedicated to the practical realisation of low noise wideband toroid transformers together with Network Analyser measurement data.
Kind regards,
Kind regards,
can you please let me know what it is that you used to generate the signal so you cold test your filter?
Hi Illlm,
I use a wideband noise generator sold on ebay for 15 USD approx. You can find details & pictures of the measurement setup here:
and here:
Remeber to use a supply voltage of maximum 10 V with the noise generator. Higher voltages are not safe as I discovered to my own cost.
and here:
HIGH IMPEDANCE FILTER CHEBYSHEV N=9 / 0.1 dB RIPPLE / 560 to 560 OHM
Development and construction of this filter with a new layout & winding coil method went much quicker than anticipated and I am able to upload some measurements taken on the finished filter assembly, before mounting into the die cast box. Filter performs well and offers a SWR below 1.5 up to 15 MHz and a SWR below 3 up to 29 MHz. All details in the next posts.
- High Pass Chebyshev N=9, r=0.1 dB, 560 to 560 Ohm - Bandpass plot to 6 MHz
- HIP HI Z Bandpass 6 MHz.jpg (149.65 KiB) Viewed 3620 times
- High Pass Chebyshev N=9, r=0.1 dB, 560 to 560 Ohm - SWR near cutoff frequency
- HP Hi Z 1K-3K SWR.jpg (102.69 KiB) Viewed 3620 times
- High Pass Chebyshev N=9, r=0.1 dB, 560 to 560 Ohm - SWR to 10 MHz
- HP HI Z 1.5K-10K.jpg (103.57 KiB) Viewed 3620 times
