SDRuno and DMR decoding with DSD+
g8ixn
Re: SDRuno and DMR decoding with DSD+
Post by g8ixn » Thu May 30, 2019 2:55 pm
Try this as has been also said in this thread turn off the deemphasis
https://www.youtube.com/watch?v=bS1KBGlUoZ0
Patrick73
Post by Patrick73 » Thu May 30, 2019 7:22 pm
Does anyone know if it's possible to decode TETRA with a RSPduo ?
Thanks !
Patrick73
Post by Patrick73 » Mon Jun 03, 2019 6:34 pm
So, it looks like it's not possible :|
StandingWave
Post by StandingWave » Tue Jun 04, 2019 9:41 am
From my research so far, there seems to be a plugin available for SDR#.
https://www.rtl-sdr.com/tetra-decoder-p ... available/
https://www.rtl-sdr.com/sdr-tetra-plugi ... res-msys2/
https://www.hamdigitaal.nl/2018/01/tetr ... -voor-sdr/
This will work with an RTLSDR dongle, but unfortunately, it seems that the SDR# software does not support RSP radios.
The other option I found was Telive which is for Linux which works in conjunction with GNUradio:
https://www.rtl-sdr.com/rtl-sdr-tutoria ... -channels/
https://www.rtl-sdr.com/bootable-linux- ... available/
It seems that Telive can also be run on Windows:
https://www.rtl-sdr.com/tetra-decoding- ... th-telive/
The links above describe the setup with an RTLSDR, but GNUradio uses SOAPSDR which can link up with an RSP:
https://www.sdrplay.com/community/viewtopic.php?t=2574
The setup looks rather complex and although I had hopes of being able to set this up sometime, but so far I have only compiled Telive. At this point, I don't know whether its viable yet.
Patrick73
Post by Patrick73 » Wed Jun 05, 2019 7:18 pm
Hi StandingWave,
Thanks for reply and the several links.
I was aware of the TETRA plugin for SDR# but I'm looking for something I could use with the RSPduo. I don't know Telive but it indeed seems a bit tricky to set up ! At last for me.
Considering there are hundreds of TETRA signals in the 400-500 MHz range,I hope someone will soon provide a simple decoder for the RSP. It's a bit frustrating not to be able to decode them with such a powerful soft/SDR.
Regards
