Morse Decoding
Morse Decoding
My SDRplay easily outputs CW signals via my soundcard to my speakers ..
There is a very clever morse decoding program called CWGET by Sergei Podstrigailo, UA9OSV.
This works by decoding morse audio fed to the microphone socket of your soundcard - very nice.
Now this seems very close to having SDRplay's CW output accessible to the CWGET program - the computer's soundcard already has the SDRplay output passing though it - it's a pity the two programs aren't able to talk to each other ..
There may be some way, temptingly close, but I haven't found it yet ..
best wishes,
Graham
best wishes,
Graham
Re: Morse Decoding
Search for "Virtual Audio Cable" or VAC.
There are open source (i.e. no cost) and pay for version available for Windows which work quite well.
You may also be able to connect your speaker out to mic in your computers sound card and accomplish something similar. However, you would no longer be able to "hear" the output to the speaker and you would have to play around the configuration and settings of your computer audio mixer.
I am sure there are others here that will have more experience setting this sort of thing up and will likey be more helpful than I.
cheers, Graham ve3gtc
Re: Morse Decoding
Graham,
you just need a Virtual Audio Cable, VAC there are two options, one has a free sample for 1 cable
http://vb-audio.pagesperso-orange.fr/Cable/
this will allow you to pipe the audio from any sdr program HDSDR or SDR-Console into CWGet...
Paul - NN4F
Paul - NN4F
Re: Morse Decoding
If you have a good computer try this software, include a mixer and multiple sound cards.
http://vb-audio.pagesperso-orange.fr/Vo ... /index.htm
Re: Morse Decoding
Thanks guys - I'd never come across a 'virtual cable'
I tried it, but the only activity I noticed at one attempt, was that CWGET was trying to decode CW from the music output of Windows Media Player .. Obviously not a good idea ..
I think I need an 'Idiots Guide to Virtual Cables'
best wishes,
Graham
best wishes,
Graham
Re: Morse Decoding
There's a nice video from Andrew O'Brien showing the VAC set-up for HDSDR here: https://www.youtube.com/watch?v=CFP_2LG4qrYGWS wrote:Thanks guys - I'd never come across a 'virtual cable'
best wishes,
Graham
Re: Morse Decoding
Thanks for the suggestions guys - but it turned out to be much simpler using Windows itself ..
Here's the link showing how to use “Stereo Mix” which makes sound card output available to another program
http://www.howtogeek.com/howto/39532/ho ... ord-audio/
Once you've enabled Stereo Mixer in the Windows Sound - Recording section, it all happens automagically
CWGET starts decoding the morse directly - wonderful.
best wishes,
Graham G4EVW
best wishes,
Graham G4EVW
