sdr-console, no audio output on cw
Just getting started with the sdrplay and have found sdr-console seems to work best on my laptop. If I monitor broadcast fm or VHF ham frequencies, audio is no problem. However selecting cw and monitoring a radio beacon, nothing is heard but I can see the cw signal clearly on the waterfall.
Am I doing something wrong?
regards
Mike
regards
Mike
Re: sdr-console, no audio output on cw
This is one of the reasons I gave up on Console. Everything an be going fine, then you start looking at weak signals and...no audio. It is something that has plagued Console from the earlier versions. The other main reason is that I find Console over complex and difficult to 'drive'. I'll stick to HDSDR and SDR Sharp for now (I still have v.1361 installed).
Mike, can you do a screen shot when you are tuned to the CW signal, could be a cw bandwidth issue? Also make sure you have the autonotch turned off when in CW...
Paul - NN4F
Paul - NN4F
