SDRplay SDRSharp Plugin v2.0
Re: SDRplay SDRSharp Plugin v2.0
Postby g1hbe » Sat May 09, 2015 7:09 pm
It is a bit messy, but my main prob at the moment is that it loses the freq correction every time I shut it down. It's a pain in the backside to have to dial up -174 everytime I want to use it!
Sideteacher
Postby Sideteacher » Sun May 10, 2015 4:29 pm
The version 2.0 is indeed a port of the EXTIO. A couple of reasons for doing this,
--to allow it to work correctly with the IQ Correction in SDR#. This eliminates the images which was a real problem.
--reduces us to a single code base which makes support easier.
The other change in this version is the way in which the frequency updates are handled which should make it a little smoother
Planned changes which will follow;
Save and recall of settings.
Load defaults button
Gain text information for each stage
Scaling of the frequency display for the lower bandwidths
Some other stuff.....
Not sure I follow the grips about the look of the dialog box :( , it is basically the same as the previous version ??
Question - How smooth is the operation of the gain control slider?? smooth or jerky?
Thanks...
CaptainNemo
Postby CaptainNemo » Wed May 20, 2015 6:12 am
CaptainNemo wrote:...
B-- the annoying and frustrating "falling-from-the-hill" (the bandwith in non centered and re-centered around the tuning freq
so after some time, if you tune to higher frequency sooner or later you will find yourself going down the hill -- where the hill is the flat part
of bandwith, going down the hill means you go in a region were the filter is "filtering"... excuse my english...)
I found a way to avoid this problem.
1. install Frequency Enter plugin
2. in the sdr# config file set the "key" centerScrollLimit to 0
Now, if you change the freq using the "frequency dial" (top of sdr# screen) (and NOT by clicking here and there on the spectrum)
frequency will ever be in the center of the screen ---> the important thing is that frequency will ever be inside the bandwith.
So, point "B--", according to me is no more an issue for sdr#-sdrplay plugin.
bye
