SDRUno + VB-Cable problem
Hello group,
I try to set up my SDRPlay for data decoding.
My problem is routing the sound from SDRUno via VB-Cable to any decoding software (Multipsk, DSD+ and PDW). The signal
is strong, visible (and audible) in SDRUno, but no signal seems to reach the decoder.
In Win 10 I have the following devices available:
Playback: Speakers, Cable Input (default)
Recording: Microphone Realtek (inactive), Stereo Mix Realtek (inactive), Cable Output (default).
The default recording device "Cable Output (VB-Audio Virtual Cable)" is indicating signal at level bar, "Listen to this device" active.
SdrUNO RX Control Settings: WME Output Device set to "Cable Input (VB-Audio Virtual Cable)", output routing ch = BOTH.
Decoding software input device: Cable Output (VB-Audio Virtual Cable)
DEEM is disabled, SQUELCH and AGC as well.
I have tried to remove and reinstall the software, but no change.
Any ideas for what to try next?
Brgds Joba
Brgds Joba
Re: SDRUno + VB-Cable problem
Have you selected the proper input (or "capture device") in your decoding software? Cable Output?
73s, Heinrich
73s, Heinrich
