Won't load a new file for playback while playing a file
Using 1.11 but noticed this problem on the prior version, too: I'm playing back an SDRPlay recorded .wav file, then want to load another .wav file for playback - SDRUno allows me to navigate to and select another .wav file, but pressing green "play" button doesn't start playback. Tried using both OPT | Select Input | WAV file in MAIN window and FILE in the RECORDER window. No playback is possible until I completely close the SDRuno application and restart it, then I can select and play a .wav file. This consistently occurs all the time. Also notice on Perseus and Elad recorded .wav files.
Brett Saylor
W3SWL
Brett Saylor
W3SWL
Re: Won't load a new file for playback while playing a file
I can confirm the behavior as far as after loading another file the play button stays lit and does not react. However all I have to do is clicking stop and then the play button again to hear the other file (which is what I would have expected). So the bug could rather be that opening the file->open dialog stops playback but the transport keys/logic don't get notified about that.
Ah, that's the trick! Yes, clicking "stop" then "play" allows the next file to play. Thanks so much for the tip!
73,
Brett
73,
Brett
Now I can"t get SDRuno to open files anymore - all that works is right-clicking the recorder panel to select a recording path, and recording into that folder. No file->open dialog, file list or anything. Am I just stupid today or is that really broken?
Click on OPT in MAIN window, Select input, WAV file?
D'oh! <insert random facepalm icon here>
(After I was obviously able to find that a few days ago, I spend the following days playing a bit with recording larger swaths of spectrum in HDSDR, where you just click the play button to get a file browser, also it was very early in the morning for me and I ran out of coffee, then there was an earthquake....locusts...LOCUSTS!!)
Anyway, thank you very much, Sir!
