SDRunoExtIO no longer starts
DanubeBCL
Postby DanubeBCL » Fri Dec 23, 2016 4:28 pm
After installing SDRuno 1.12 I cannot start SDRunoExtIO any more. The programme terminates before anything is shown.
No problem when I go back to 1.11.
Has anyone got a similar problem? What could I have messed up?
DanubeBCL
Re: SDRunoExtIO no longer starts
Postby DanubeBCL » Fri Dec 23, 2016 4:40 pm
After several trials and errors I found out the follwowing:
SDRuno 1.12 copies a WRPnfdc.dll dated 02/12/2016 13:46. SDRunoExtIO does NOT start with this dll.
SDRuno uses a WRPnfdc.dll dated 24/10/2016 18:33. SDRunoExtIO starts OK with this dll.
When I copy this old dll to the new 1.12 installation SDRunoExtIO is working again.
What is the purpose of that new WRPnfdc.dll and how can we make it work with SDRunoExtIO again?
13dka
Postby 13dka » Fri Dec 23, 2016 5:32 pm
Thanks for the warning! I just got SDR#1361 kind of running and want to play a bit more with that. :mrgreen:
pa7gmu
Postby pa7gmu » Sun Dec 25, 2016 10:12 am
Hello Heinrich,
I am glad that you found the problem with SDRuno.EXTIO.exe version 1.12
I struggled with the same problems a couple of days under Windows Vista
Please, can you tell me where to find the old dll or the 1.11 version of SDRUNO
All the best and 73
Gerard
de PA7GMU
DanubeBCL
Postby DanubeBCL » Mon Dec 26, 2016 10:26 am
pa7gmu wrote:Please, can you tell me where to find the old dll or the 1.11 version of SDRUNO
Hello Gerard,
I re-installed version 1.11, made a copy of all the files in the installation directory and the installed 1.12 again. Then I copied the WRPnfdc.dll from the old installation.
But I have no clue if the new WRPnfdc.dll is also used by SDRuno and lets us miss some functions when we use the old dll. Thus I meanwhile use two different installation folders: 1.12 for the SDRPlay, 1.11 for the SDRunoExtIO.
A solution from SDRplay which adresses the problem would be better.
pa7gmu
Postby pa7gmu » Mon Dec 26, 2016 2:15 pm
Hi Heinrich,
Thanks for your answer. Where can I download the 1.11 version? I have only the 1.12 version of SDRuno and searched for an older version but can't find it.
I hope you can help me.
73 Gerard
DanubeBCL
Postby DanubeBCL » Mon Dec 26, 2016 4:26 pm
See pm here in the board, Gerard.
rdxny
Postby rdxny » Mon Dec 26, 2016 4:53 pm
Heinrich,
any chance you can post v 1.11 or the WRPnfdc.dll file somewhere , or PM me also? I have the same issue.... thanks!
-JM
DanubeBCL
Postby DanubeBCL » Mon Dec 26, 2016 5:13 pm
See pm also.
I hope SDRPlay will fix the issue soon. ;)
rdxny
Postby rdxny » Mon Dec 26, 2016 5:53 pm
That worked, Thank you!
