Centering panadapter display
I am just getting familiar with my new RSP2 running SDRuno. When I select a signal in the panadapter display the receiver moves to the signal. If I get near either end of the display I would like to re-center the display to look at other signals in that part of the band. Is there a way to center the display on the last select signal?
Phil N3ZP
Phil N3ZP
Re: Centering panadapter display
Try the button on the bottom of the SP1 screen.
It is to the right of the zoom buttons.
Good luck.
73 KD2JNF
Good luck.
73 KD2JNF
Strangely, or not, you meed to be zoomed to at least one level before the "vfo" button will work to center your display.
Thanks, that did the trick.
Phil N3ZP
Phil N3ZP
