"Failed to locate API registry entry"
tomboy
Postby tomboy » Thu Nov 19, 2015 6:42 pm
a few weeks ago I bought the SDRplay RSP, and until now I didn't have the time to set it up.
But yesterday I went to the SDRplay website, downloaded the required items for using HDSDR, and installed them, as follows:
- installed Mirics SDR API and HW Driver
- plugged in the RSP
- installed HDSDR
- ran HDSDR to confirm that the EXTIO button was not active yet
- installed SDRplay EXTIO (into the HDSDR folder, as required)
- ran HDSDR again and got an error message to the effect of "SDR hardware not found"
- uninstalled everything, turned the computer off, and went to work
Today's installation:
- installed HDSDR
- ran HDSDR again and got an error message "Failed to locate API registry entry HKEY_LOCAL_MACHINE\Software\MiricsSDR\Tools Error 127"
- uninstalled everything, used CCleaner to clean the registry, rebooted, re-installed as above
Still getting the "failed to locate API registry entry" error.
My computer: ASUS X205TA with Windows 10
Would appreciate some words of wisdom concerning the installation problems.
Re: "Failed to locate API registry entry"
Postby Tech_Support » Thu Nov 19, 2015 8:03 pm
Dear Tomboy,
Please contact support@sdrplay.com and we will try to sort this out for you.
Yours sincerely
Postby sdrplay » Thu Nov 19, 2015 8:52 pm
Hi Tomboy,
Can you confirm whether you have a 64bit or 32bit OS?
Also, can you run the Mirics SDR Evaluation Tool that is installed with the API - does this appear?
Ideally I would like to see the registry entries - either I can talk you through how to do this or I'm happy to log in remotely via teamviewer and do this directly. Please let us know whether you would be ok with that. Easiest is to contact us at support@sdrplay.com
tomboy
Postby tomboy » Fri Nov 20, 2015 10:16 pm
Thanks for the replies. I'll get back to you after work. :-)
DaveUdon
Postby DaveUdon » Sat Feb 25, 2017 2:08 am
About 15 months ago... but what was the solution from Support? (No contact info for Tomboy...)
I am having the same problem now with the latest HDSDR v2.76 and EXTIO.ddl v3.9.1 in a Win-7 physical partition on my 64-bit i5 Acer laptop. I followed the exact same procedure as Tomboy before I came across his post.
The HDSDR/EXTIO.dll installed smoothly in a 64-bit Win-10 VirtualBox guest on an Intel i5 Nuc with Linux host.
I compared the registry reference on both machines and they are exactly the same... no /Tools item appears.
My temporary solution was to copy the working VB Win-10 guest across to the laptop's VB where it runs smoothly.
Still, I would like to elevate my "install trust factor" in the latest SDRplay software.
Regards from NE Thailand
Postby sdrplay » Sat Feb 25, 2017 8:19 am
It's important to make sure the EXTIO dll is compatible with the API version. If you are not sure, then go to our downloads page and install either...
EXTIO PLUGINS - VERSION 1.0 (if you want to use your existing HDSDR installation)
or
HDSDR – VERSION 2.76 (which contains HDSDR, API and EXTIO all in one download)
DaveUdon
Postby DaveUdon » Mon Feb 27, 2017 11:07 pm
Yes, thank you for your helpful reply!
Just before I saw it, I successfully tried DanubeBCL's suggestion from viewtopic.php?f=7&t=1917
"Re: Hdsdr v 2.76
Post by DanubeBCL » Thu Feb 02, 2017 5:11 pm
I think the easiest way for you is to download the package "HDSDR – version 2.75 Beta3" from here and install it:
http://www.sdrplay.com/downloads/
Then you load HDSDR 276 from http://www.hdsdr.de and simply over-install it."
Including HDSDR, API and EXTIO all in one download of HDSDR – VERSION 2.76 is the best solution and will save a lot of misunderstanding... I'm off and running with a fine SDR product...
Regards from Dave HS0ZGR / K2DZ in NE Thailand
DanubeBCL
Postby DanubeBCL » Tue Feb 28, 2017 10:35 am
http://www.sdrplay.com/downloads/ in the meantime already includes HDSDR 2.76.
