getting started android tablet with RSP2
wireman
Postby wireman » Wed Apr 05, 2017 1:55 pm
Hi all, What cable and app do i use for a standard android tablet please ?
W2DLC
Re: getting started android tablet with RSP2
Postby W2DLC » Thu Apr 06, 2017 2:11 pm
You need to download the beta SDRPlay driver first. Then there are a couple of apps available. The best is probably SDR Touch. The cable is called OTG cable, but you can get one with a plug to provide power, and that might be best. Just make sure it will power the tablet while transmitting data. some won't .
pticafilin
Postby pticafilin » Mon Apr 10, 2017 10:58 am
At this moment there are android apps supporting only RSP1.
As far I know RSP2 is not supported yet.
wireman
Postby wireman » Fri Apr 14, 2017 12:05 am
ok thanks for the info guys
ekendraed
Postby ekendraed » Sun Apr 16, 2017 5:59 am
Would like to know if and when RSP2 PRO will work with an Android Tab. Thank you
mikexeno
Postby mikexeno » Fri Apr 28, 2017 7:59 pm
Best bet is to check the blog section. As soon as it get update from SDRtouch I am sure Jon will post the information ASAP
http://www.sdrplay.com/blog/
Users browsing this forum: Bing [Bot], kaktus69 and 6 guests
