sdr# questions
sdr# questions
I previously posted this on "Code Corner." then thought that this might be a more obvious place and I wanted to add another query anyway.
Having finally downloaded, installed and successfully run SDR# Rev 1361 with SDRPlay RSP2, I am now having difficulty sourcing a File Management suite version that is compatible with this version.
Also, when accessing SDRPlay settings, the programme offers only antenna ports A and B bias T enabled - is this correct, as it looks as if the A option is in a "scrollable" window, but does not do so?
Any suggestions gratefully received.
I'm certainly not "Jumping ship" from SDRUno - just want a functioning AM/FM scanner.
Re: sdr# questions
Maybe you mean Frequency Manager suite... ???Paul wrote:...File Management suite ...
If yes try asking to the author, he is a very kind guy, maybe can arrange to send
you a zip of the old version 1...
gio
