Here, CubicSDR, all SDR-s detected, first two working, last RSP1 detected, but not able to work....
- Screenshot from 2017-07-10 08-54-16.png (35.24 KiB) Viewed 28588 times
Probe ->
q@q-X756UX:~$ SoapySDRUtil --probe=sdrplay
Probe device sdrplay
mir_sdr_usb_GetDevices Dev0:vid=1df7 pid=2500 rev=0206 serno=B0001P0004 bus=001 port=004 devAvail=1
mir_sdr_usb_SetDeviceIdx idx=0 numDevices=1
Opened device with idVendor = 0x1df7 idProduct = 0x2500 fwVersion = 0x0206 busNum = 001 portNum = 004
mir_sdr_Init: gR=60dB fs=2.000MHz rf=98.800MHz bw=1.536MHz if=0.000MHz
DownConvert: Enable=0 DecM=1 OutScale=0 (fs=2.000000 bw=1536 if=0)
mir_sdr_2500_Init: fnaddr = 7
initHw: Register7 = 0x000014
initRfFreqDependentHw(1): Tuner Register0 = 0x04f420
mir_sdr_SetFs: Sample Freq requested 2000000.000000
mir_sdr_SetFs: Fs->FsNomHz+dFsHz=2000000.0+0.0Hz=2000000.0Hz FsToggle->1
mir_sdr_SetRf: f->98800000.000Hz (int=20 frac=af0 afc=0) fSynth:3161600000.000
mir_sdr_SetRf: Rf->RfNomHz+dRfHz+LifHz+Lif1Hz=98800000.0+0.0+0.0Hz+0.0Hz=98800000.0Hz RfToggle->1
mir_sdr_SetGr: GR->60[36,24,0,0] gRset->0x224 DCCALmode=3 DCCALspd=0 GrToggle->1
mir_sdr_usb_StreamRead: Read failed to read sufficient data: requested 393216 read 0
mir_sdr_2500_StreamRead: Read failed
mir_sdr_usb_StreamUninit: Stream stop timeout (4000 0)
mir_sdr_2500_StreamRead: Read failed again
setToggleStates: failed mir_sdr_2500_StreamRead err=1
initHw: setToggleStates() Error 1
mir_sdr_Init: initHw returns error 7
Warning: DriverCallback() couldn't match transfer 0x55aefa543120
Warning: DriverCallback() couldn't match transfer 0x55aefa53ed00
Warning: DriverCallback() couldn't match transfer 0x55aefa52a6c0
Warning: DriverCallback() couldn't match transfer 0x55aefa52b3e0
Warning: DriverCallback() couldn't match transfer 0x55aefa52c100
Warning: DriverCallback() couldn't match transfer 0x55aefa52ce20
Warning: DriverCallback() couldn't match transfer 0x55aefa52db40
Warning: DriverCallback() couldn't match transfer 0x55aefa52e860
mir_sdr_2500_Readback001Trim: readback = 0xd1c020f
mir_sdr_2500_Bypass001Trim: reg13=0x1ed reg14=0x47002e
Trying to open device with mir_sdr_Init failed
mir_sdr_usb_SetDeviceIdx: Unable to access EEPROM
-- Device identification
driver=SDRplay
hardware=1 B0001P0004
mir_sdr_api_version=2.100000
mir_sdr_hw_version=1
-- Peripheral summary
Channels: 1 Rx, 0 Tx
Timestamps: NO
Other Settings:
[key=rfgain_sel, default=1, type=string, options=(0, 1, 2, 3)]
-- RX Channel 0
Full-duplex: YES
Supports AGC: YES
Stream formats: CS16, CF32
Antennas: RX
Corrections: DC removal
Full gain range: [0, 39] dB
IFGR gain range: [20, 59] dB
CORR freq range: MHz
Sample rates: 0.25, 0.5, 1, 2, 2.048, 6, 7, 8, 9, 10 MSps
Filter bandwidths: 0.2, 0.3, 0.6, 1.536, 5, 6, 7, 8 MHz
mir_sdr_usb_ReleaseDeviceIdx 0
q@q-X756UX:~$
On other PC under win10 all is in order. Before on ubuntu 16.04 ok too.
Best Regards
Djani
